Reserve BW for Video Conferencing
rvg2k
We have a Cisco 1841 router at Branch end and a Cisco 2821 router at the HO connected by a 2MB Leased line. There is a Video Conferencing device setup in the branch office . We want to reserve 1MB bandwidth for the video conferencing and leave the remaining BW for Data . The traffic between the locations is passed through the tunnel using the static routes . Please suggest the suitable solution  .
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
CBWFQ with 1 Mbps "reserved" for video should do.  This might be applied, depending on platform and/or IOS version, on the tunnel interface or the physical interface.  Actual CBWFQ may vary somewhat also depending on platform and/or IOS version.
Why a tunnel on a leased line?  Is the lease line dedicated p2p or running across some kind of "cloud", like the Internet.  If the latter, is there non-tunnel traffic across the leased line too?
Hi there
first of all you need to identify how and what type fo marking you video endpoint mark the signaling and RTP/media traffic ?
if you are not sure then you could use ACL to match all traffic coming from the VC endpoint and match with class match
normally with video traffic get marked as DSCP AF41 but this is something you need to find out always do not mark VC RTP as video and audio just keep it one bundle
example using ACL to match all traffic from the VC endpoint
ip access-list 100 permit ip host x.x.x.x any
class-map VC
match ip access-group 100
policy-map CE-EDGE
class VC
bandwidth 1000
above used CBWFQ as video is a bit less sensitive than VOIP but is it more busty traffic
shaping interface ( for buffer with VC busty traffic )
policy-map QoS-2M
class class-default
   shape average 2000000 1000000
   service-policy CE-EDGE
int fax/x   outside interface
service -policy output QoS-2M
- you mentioend tunnel in the post not sure if you are using VPN or GRE tunnle interface and why ? if yes although this is not good with video but you need to apply the above policy to the tunnel interface
if helpful Rate
