Virtual-Template Interfaces (VTI) types
satv
Hello !
I need some inputs on Virtual-Template interfaces.
1) What are the most used configurations( set of clis)  for all the 3 types of VTI interfaces  1)  Type Serial 2) type Ethernet 3) Type Tunnel ?
2) What scenarios each of these 3 types of VTI are used ?
Rozsa Illes
I am not so familiar with Serial and Ethernet type Virtual Template interfaces but you can read a bit more about them in general here:
http://www.cisco.com/en/US/docs/ios/12_0/dial/configuration/guide/dcvtemp.html
Tunnel type VTI are generally used with EZVPN and this link would give information and configuration examples for both static and dynamic VTI (dynamic VTI uses the virtual template interface, static vti uses tunnel interface):
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gtIPSctm.html
I hope this helps.
Warm Regards,
Rose
Thanks Rozsa,I have come up this cli set.
1)      type serial
interface virtual-template type serial
encapsulation {ppp|frame-relay|slip}
description
mtu
bandwidth
full-duplex|half-duplex
ip address {secondary}
ip unnumbered
ip address pool
ip address negotiated [previous ]
ip address dhcp client-id {Port-channel | GigabitEthernet } {hostname }
2)      type tunnel
interface virtual-template type tunnel
description
mtu
bandwidth
ip unnumbered
ip address pool
tunnel source {ip-address | interface-type interface-number}
tunnel destination
tunnel mode {aurp | cayman | dvmrp | eon | gre | gre multipoint | gre ipv6 | ipip [decapsulate-any] |ipsec {ipv4|ipv6}| iptalk | ipv6 | mpls | nos}
tunnel protection IPsec profile (applicable when mode is ipsec {ipv4|ipv6})
3)      type ethernet
interface virtual-template type ethernet
description
mtu
bandwidth
duplex {full|half}
ip unnumbered
ip address pool
