Reset a 2600
IT_-_Department
I have a 2600 Router that has been donated to my use for some lab work.  The thing was locked down pretty well.  I have console access to it (obviously) but there is a console PW assigned.  How can I reset the silly thing back to factory defaults including wiping the con PW?  I cannot get to it to reset the boot register from 2102 to 2142 or similar.  Is there a way to bypass this and reset the device?
vmiller
Level 7
Level 7
did you try this?
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml.
the trick is making sure your term emulatior is sending the break key.
Keep in mind that is ctrl+break and not break alone. You need to press at least three times within 60 seconds and you'll see you will be in. As above suggested, if ctrl + break does not work, change terminal emulator. the rest is what is described in vmiller link.
Take care
Alessio
I am using Putty and there is a special command option, but I am pretty sure that is sending just a Break not Ctrl + Break.
I need to find another Terminal Emmulator that will send the Ctrl + Break and hope that will reset the Router to Factory Default boot, as I cannot get into the Con Port without the set PW so I cannot follow the steps in the above link.
I will post here what happens next when i get a chance to try another Term Emm product.
Hi Eric,
this is what you can do with Putty:
hope this helps
Alessio
