reset cisco therm-7606S
Baptiste
Do you have a documentation to reset the cisco without the password?
I do like this:
I go into the rommon and I type confreg 0x2102 and then I type the reset command.
Is this correct?
 Use the config Register of 0x2142
"Note: Also remember that configuration register 0x2142 is used for Password Recovery procedures as it can ignore the contents of NVRAM."
M02@rt37
Bonjour @Baptiste ,
il faut le confreg en 0x2142 !
C'est bon pour toi ?
Best regards
