RESOLVED - Cisco RV180 W vpn to vpn
itgs_cisco
Hello
I did a vpn to vpn between two RV180 W. I can establise a connection but after a while in the two device i get IPsec SA Not Established
Could someone help me with this problem ?
Thanks for the answer
Best regards
gic
Roberto Kippins
the isakmp session will time out if no traffic is going across the tunnel can you setup ip sla to send pings through the tunnel? this will keep it active.
thanks for your answer.
It's possible to do that in a cisco Rv180 W ?
Hi I am not sure does it have a console port or a web interface I willl research the device
Thanks for your answer.
I found the solution. Go to Firewall - Attack Prevention and disable Stealth Mode. My vpn tunnels keep alive.
