Restrict 512Kbps bandwidth to some workstations
hamidrezaaf
we have 3 workstations which have static nats.
How can you restrice at most 512 kbps bandwidth to these workstations ?
Hamid
7 Replies 7
sean_evershed
Level 7
Level 7
Do you manage the firewall? If so you could police bandwidth based on IP addresses. See below
https://supportforums.cisco.com/docs/DOC-1230
Don't forget to rate posts that are helpful.
sorry for my unattention
we want to config a router cisco 2851(c2800nm-adventerprisek9-mz.124-24.T6.bin ios).
You're probably going to have to shape outbound and police inbound to 512k to your natted addresses.
Let's say that you have addresses 192.168.1.50 - 52 and they map to 5.5.5.50 - 52, you could do something like this:
ip access-list ext Shape
permit ip host 5.5.5.50 any
permit ip host 5.5.5.51 any
permit ip host 5.5.5.52 any
ip access-list ext Police
permit ip any host 5.5.5.50
permit ip any host 5.5.5.51
permit ip any host 5.5.5.52
class-map match-any Shape
match access-group name Shape
class-map match-any Police
match access-group name Police
policy-map Police
class Police
police 512000
     exceed-action drop
policy-map Shape
class Shape
shape average 512000
int s0/0 (outside interface)
service-policy input Police
service-policy output Shape
HTH,
John
Please rate useful posts...
HTH, John *** Please rate all useful posts ***
Many thnaks for your comment
Does below configs convey us to our desired purpose ?
ip nat inside source static 192.168.10.50 X.X.X.10 extendable
ip nat inside source static 192.168.10.51 X.X.X.11 extendable
ip nat inside source static 192.168.10.52 X.X.X.12 extendable
interface GigabitEthernet0/0
description $ETH-LAN$
ip address 192.168.10.1 255.255.255.0
ip access-group 150 in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-WAN$
ip address X.X.X.226 255.255.255.224
ip nat outside
duplex auto
speed auto
permit ip host X.X.X.50 any
permit ip host X.X.X.51 any
permit ip host X.X.X.52 any
permit ip any host X.X.X.50
permit ip any host X.X.X.51
policy-map Police
class Police
police 512000
exceed-action drop
policy-map Shape
class Shape
access-list 150 deny   tcp any eq 1034 any log
access-list 150 deny   tcp any eq 1080 any log
access-list 150 deny   tcp any eq 1214 any log
access-list 150 deny   tcp any eq 2535 any log
access-list 150 deny   tcp any eq 1433 any log
access-list 150 deny   tcp any eq 3127 any log
access-list 150 deny   tcp any eq 2745 any log
access-list 150 deny   tcp any eq 4444 any log
access-list 150 deny   udp any eq 1434 any log
access-list 150 deny   udp any range 135 netbios-ss any
access-list 150 deny   tcp any range 1036 1037 any log
access-list 150 deny   tcp any any eq 81 log
access-list 150 deny   tcp any any eq 445 log
access-list 150 deny   tcp any any eq 1080 log
access-list 150 deny   tcp any any eq ident
access-list 150 deny   tcp any any eq 1214
access-list 150 deny   tcp any any eq 2745
access-list 150 deny   tcp any any eq 5101
access-list 150 deny   tcp any any eq 5554
access-list 150 deny   tcp any any eq 6129
access-list 150 deny   tcp any any eq 9996
access-list 150 deny   udp any any eq 1434
access-list 150 deny   tcp any any eq 11768
access-list 150 deny   tcp any any eq 15118
access-list 150 deny   tcp any any range 1022 1025
access-list 150 deny   tcp any any range 135 139
access-list 150 deny   udp any any range 135 netbios-ss
access-list 150 permit tcp any any eq 443
access-list 150 permit udp any any eq domain
access-list 150 permit tcp any any eq domain
access-list 150 permit tcp any any eq 8181
access-list 150 permit tcp any any eq 8080
access-list 150 permit tcp any any eq 1433
access-list 150 permit ip any any
Hamid
Hamid,
You police on the traffic before it's natted and shape after it's natted. So you're acl will reflect the public addresses.
John
Dear j,blakley,
do you have a better solution ?
Hamid
Hi Hanidrezaaf,
A different approach to your problem is to use GTS (generic traffic shaping)
The syntax of the command is the next
traffic-shape rate bit-rate burst-size excess-burst-size
The next config can be applied to  the ethernet (LAN) interface in order to limit all output to 512k
interface LAN-per user
 traffic-shape rate 512000
Then you can apply the next config to the WAN interface to limit the output to 512 for each of the 3 users
interface
traffic-shape group 101 512000
traffic-shape group 102 512000
traffic-shape group 103 512000
Where 101,102,103 are the Access lists that match the user traffic
Hope that helps,
Vasilis
Please rate the useful posts
