Restricting multicasting and rate limiting traffic on 3560
thundercisco
Please see the attached diagram. My issues is
  1. i have to restrict that router and switches shall join only given multicasts. Means if i change multicast in TVG430 from 239.0.96.1 to 233.0.96.1 than it shall be blocked.
  2. My TX rate i set to 20 Mbits on TVG430, i want to rate-limit it to 15 Mbits on switch on Ingress int gi 0/23 or egress gi 0/24
included are three show runs output.
Till now i have tried to use
ip multicast rate-limit out group-list GROUP source-list SOURCE
Didn't work
//Tiwana
Latchum Naidu
Hi Tiwana,
See the below two individual steps may help in your scenario.
STEP-1:
Apply rate-limit on each L3 vlan interface in your 2851
Example (for 1024kbits for vlan 2):
Router# conf t
Router(config)# int vlan 2
Router(config-if)#rate-limit input 1000000 187500 375000 conform-action transmit exceed-action drop
Router(config-if)#rate-limit output 1000000 187500 375000 conform-action transmit exceed-action drop
STEP-2:
Policy a specific VLAN number on VLAN interface.
class-map vlan5
match vlan 5
match class-map class-default
policy-map vlan5-limit
class vlan5
police 2000000 250000 exceed-action drop
int vlan5
service-policy input vlan5-limit
After you apply this configuration, the traffic with VLAN 5 coming from any will be policed at 2Mbps.
Hope this will help you.
Please rate the helpfull posts.
Naidu.
I guess above steps that you mentioned are for switch called vnl-msw58-trf1.  I tried it on the switch but following commands are not supported under class-map
match vlan 5
i am running  following ios
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Thnx for ur quick response.
