Restricting router from connecting with some vlans
arontig
how do we restrict a router interfaces from directly connected to Some vlans? can any one help me to figureout?
the question is
  • Router should not have interfaces directly connected to Vlan 30 and Vlan 40
balaji.bandi
If i understand correctly you looking to block between VLAN communication with ACL ?
snippet from notes :
access-list 30 deny ip source/mask destination/mask
access-list 30 perit ip any any
access-list 40 deny ip source/mask destination/mask
access-list 40 permit ip any any
int vlan 30
  ip access-group 40 in
int vlan 40
  ip access-group 30 in
BB
Joseph W. Doherty
Unclear what you're asking, as normally, if we're talking about an "external" router, you need to, physically and/or logically, connect the router (somehow) to the VLANs (often via a trunk between a router and L2 switch). You just don't "connect" the VLANs you want to exclude. If your "router" is a L3 switch, you might have VLANs defined on the switch but without SVIs. As already noted by Balaji, you can selectively block, or block all, traffic to and/or from those VLANs using ACLs. In this cast, the VLANs are "connect" but traffic cannot move between them. Lastly, some devices support various forms of virtual L3. For those, something like VLANs 30 and 40 might be logically partitioned from all your other VLANs.
arontig
Sorry for making it a little bit unclear, I have the topology like below
[cid:adc88aea-b2e7-43dd-97a8-2fe994f31a69]
VLAN Table
VLAN
VLAN Name
Finance
20
Sales
30
HR
40
IT
99
Blackhole
so what I am looking for is, R2 should not have interfaces directly connected to Finance and Sales. How can we configure that?????
balaji.bandi
there are couple of options .
1. you can make VRF to not to interact with each other (that is complicated for small kind of setup)
2. Terminate them different segment with FW in place (this is additional administration task to manage FW)
3. So the option i have given above is simple ACL which give you ability that both deparments  not communicated between Finance and sales at all.
in your case VLAN 10 and VLAN 20 - so change the ACL as per the requirement.
BB
