reverse route
dhanikonda
Dear All,
i have cisco 4510 switch connected intranet link to one of the ports and created vlan that vlan gateway routable from firewall from that vlan iam able to ping ping other vlans .
now my remote network admin is telling
Please configure a reverse route for our network, so that  it can be access from SWAN (state wide area network)network also.
SWAN  Network Address 10.0.0.0/16.
so if iwant to add reverse route means i have to add in firewall or core switch how can i add reverse route.
please advice me.
Srini
Are you using your firewall as a  routing device or core switch ?
Add reverse route in your routing devices which does the routing in your network.
V.S.Suresh.
