04-14-2011 01:41 AM - edited 03-04-2019 12:04 PM
hi all
what is RIB failure in BGP ? in what conditions it is caused ? how can we avoid it ?
in my toplogy routes are not propogated due to bgp RIB failure ..plz help
Solved! Go to Solution.
04-14-2011 02:22 AM
mirehteshamali wrote:
hi all
It's usually when BGP cannot insert a route it has learnt from a peer into the routing table because there is already a route with a lower AD. Have a look at this doc -
http://blog.ioshints.info/2007/12/what-is-bgp-rib-failure.html
if it still doesn't help can you post some info so we can help further eg. "sh ip bgp" and "sh ip ro"
Jon
04-14-2011 02:22 AM
hi all
Jon
04-15-2011 05:23 AM
Thanks for reply
the issue is resolved now
