RIP is not working in Cisco packet tracer
chabiul
I have configured the RIP routing into my cisco packet tracer. But it is not working. I have uploaded the Cisco packet tracer file for your kind support.
2 Accepted Solutions
@chabiul
 RIP is only one of your problem. But, besides configuration, you also have design problem. The switch you added is a layer2 device and it does not support "ip routing". If you want to add IP address on the switch, change to another model.
The DHCP scope you created on the swtich 2 is delivering wrong default gateway.
ip dhcp pool 30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.0
dns-server 8.8.8.8
The interface between switches and Routers must not be a trunk. They need to be access as the Router interface is layer3 interfaces.
On router 2, you need to advertise the network 192.168.30.0 on RIP
you also need to advertise the network  192.168.200.0 on Router 1
And the network 192.168.100.0 on router 0
You dont need to advertise remote networks on RIP.
You can start with those errors.
chabiul
Many thanks for your reply.
M02@rt37
Hello @chabiul
Please follow this:
https://computernetworking747640215.wordpress.com/2018/07/05/rip-configuration-in-packet-tracer/
Best regards
@chabiul
ip dhcp pool 30
dns-server 8.8.8.8
chabiul
