rip receive disable
Hi.
I have ISR 2821.
How can i forbid to received  rip packet?
I want send packets only.
Jon Marshall
You could either -
1) use a distribute list inbound to stop RIP receiving any routes although it would still be receving RIP updates.
It just wouldn't put them in the routing table
or
2) if there is only one other router on the same network segment make that routers interface passive which means it won't send any RIP updates out of the interface.
Obviously if there are other routers on the same segment that need to receive RIP updates that wouldn't work.
Jon
Jon is completely right for preventing rip updates to be installed into the routing table or using passive interface for not sending rip updates.
If you want to completely block rip packets you have to use an ACL
Example:
access-list 101 deny udp any eq rip any eq rip
access-list 101 permit any any
