06-02-2005 06:34 AM - edited 03-03-2019 09:43 AM
Our NY site has added a route for a client 206.13.128.0/17 which is advertised to us over our T1 multilink and is seen in the routing table.
However, it's not being populated to our Core routers.
Core routers send V1 and receive V1 & 2
Edge routers send and receive V2
Did a debug on RIP and saw the advertised route on both edge routers, so I cannot understand why it's not forwarding the route to Core router.
Jun 2 10:12:15 EST: 206.13.128.0/17 via 0.0.0.0 in 5 hops
Show ip route 206.13.128.0 displays the following
ny-tortr01#sh ip route 206.13.128.0
Routing entry for 206.13.128.0/17, supernet
Known via "rip", distance 120, metric 1
Redistributing via rip
Last update from 192.168.13.29 on Multilink1, 00:00:09 ago
Routing Descriptor Blocks:
* 192.168.13.29, from 192.168.13.29, 00:00:09 ago, via Multilink1
Route metric is 1, traffic share count is 1
I don't understand why this one route isn't being advertised to the LAN with the other routes from the edge router, can someone share some insight please!
06-02-2005 07:29 AM
Is version 2 command enabled under the RIP process of the both core and edge routers ?
06-02-2005 08:25 AM
Version 1 is enabled on both by default, but the Multilink interface is sending and receiving V2.
As listed below!
Edge routers
Default version control: send version 1, receive any version
Interface Send Recv Triggered RIP Key-chain
Multilink1 2 2
Automatic network summarization is not in effect
Core routers
Fa0/0 1 1 2
06-02-2005 09:19 AM
Anthony
I am not positive but I believe that this section quoted from FRC 2453 may explain the behavior that you are seeing:
On an interface where a RIP-1 router may hear and operate on the information in a RIP-2 routing entry the following rules apply: ... supernet routes (routes with a netmask less specific than the"natural" network mask) must not be advertised where they could be misinterpreted by RIP-1 routers.
Rick
06-02-2005 07:56 PM
Thanks very much for pointing this out to me, the RFC was actually correct. Once redistributing the route in its natural network mask, the problem was solved!
Thanks again.
