RIP Setup Question
lawrimorer
I have a test network setup with the following subnet: 10.238.14.0; 10.238.46.0, and 10.238.122.0 all with subnet mask of 255.255.255.0.
How would I setup RIP on all three routers I am using.
Router1 attached to 10.238.14.0
Router2 attached to 10.238.46.0
Router3 attached to 10.238.122.0
I have attached a PDF of the basic layout of the test network I am using.
Thanks for all the help.
include all major networks under "router rip"
router rip
version 2
network 192.168.1.0
network 10.0.0.0
no auto-summary
Also check connectivity (ping) and your routing protocol environment (show ip protocols).
Hope this helps! Please use the rating system.
Regards, Martin
mheusinger
Level 10
Level 10
RIP needs a network statement to tell it, which interfaces should take part in RIP. For all your routers the following config would achieve RIP routing between them:
router rip
version 2
network 10.0.0.0
no auto-summary
Comments:
1) the default is RIPv1 and to change this you need the version command; can be checked f.e. with "show ip protocols"
2) the network statement is always classful even with RIPv2 supporting VLSM
3) In your environment "no auto-summary" does not make a big difference. But just in case you want to include IP addresses from other major networks (class A, B, C) this command is recommended.
Regards, Martin
Ok, I have done that on all three routers but they will not route still.
sho ip route is similar to this on all three.
C 192.168.1.0 is directly connected, serial1
10.0.0.0 is subnetted, 1 subnets
C 10.238.14.0 is directly connected,Ethernet0
Is there something special that needs to be done is all 3 networks are 10.0.0.0 networks
router rip
version 2
network 192.168.1.0
network 10.0.0.0
no auto-summary
Regards, Martin
