RIPv1
ohassairi
Level 5
Level 5
                   hello
suppose we have the following diagram with ripv1 enabled
RIPv1 does not send the mask. so R2 will see in the update message a route to 192.168.1.0 that is less specific than 192.168.1.128/25
so why it will not add it to its routing table as 192.168.1.0/24 so that it will have 2 routes :
R  192.168.1.0/24   via 192.168.0.1
C  192.168.1.128/25  via e0
this will not make any confusion for R2
cadet alain
When R2 receives the update it will see if it is in the same major network as the receiving interface which is not the case here( it receives a 192.168.1.0 and it is connected to 192.168.0.0) so it checks if any subnets of the received network already exist in the rib and it is the case here with 192.168.1.128/25 and so it ignores the update.
Regards.
Alain
siddiqirf
No, because to get to all other ip routes/hosts that do not fall into 192.168.1.128/25 (ie. 192.168.1.1/25),  R2 will follow the 192.168.1.0/24 route across the WAN link.
cadet alain
Regards.
Alain
