Virtual access interface - Why?
Pradeep H A
Level 3
Level 3
Hi all,
I have 2620XM router. on which I see a virtual-access1 interface. there are no virtual-templates configured on the router neither there is any IP configuration on it. What is the purpose of having such an interface & it seems it was automatically created?
Router#sh ip int brief
Interface                        IP-Address      OK?         Method   Status             Protocol
FastEthernet0/0            10.123.1.1       YES        NVRAM     up                    up
Serial0/0                       unassigned      YES        NVRAM     up                    up
Serial0/0.100                <<<IP>>>>      YES        NVRAM     up                    up
Virtual-Access1            unassigned      YES        unset         up                    up
Loopback0                    <<<<IP>>>      YES       NVRAM      up                    up
Router#sh int Virtual-Access1
Virtual-Access1 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1492 bytes, BW 100000 Kbit, DLY 100000 usec,
  Base PPPoE vaccess, loopback not set
  DTR is pulsed for 5 seconds on reset
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 18w0d
  Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 carrier transitions
Router#sh run int Virtual-Access1
Building configuration...
Current configuration : 61 bytes
interface Virtual-Access1
no ip address
ip mtu 1500
end
Thanks in advance
0 Replies 0
