RIPv2 question
The_guroo_2
Level 2
Level 2
Suppose We have a CE router which has Ip address of 1.1.1.1 and PE router has Ip of 1.1.1.2
from CE we have to advertise on network the command will be as below
router rip
version 2
network 10.0.0.0
no auto summary
Do i have to advertise the 1.0.0.0 network ???? keeping in mind that is the WAN addressing
never worked on RIP so thanks guys if someone can answer this
Akash Agrawal
ofcourse. Network 10.0.0.0 does not cover ip add 1.1.1.x. So you need to advertise 1.0.0.0 network.
so if the WAN interface had 139.5.6.132/30 (subnet)
our side 139.5.6.133/30   -------------> remote side 139.5.6.134/30
should we add the following config
139.5.6.132
or
139.5.6.0
Keeping in mind its /30
regards
Remember that if you use "no auto summary" command you must specify the subnet, for example :
network 139.5.6.132 255.255.255.252
