RMON upgrade syntax for 6509
emmanuel.bot
Can anyone assist with step by step instructions to upgrade the rmon in a catalyst 6509?
umedryk
Level 5
Level 5
No, the Workgroup Catalyst switch does not need any special hardware upgrades in order to utilize full RMON functionality.
You need to upgrade your DMP and NMP software on the Workgroup Catalyst switch to version 3.2 or later. Version 3.1 does not allow you to poll RMON data from conventional SNMP managers. This version is designed to work only with the TrafficDirector software. If you already use a later version of the DMP and NMP software, issue the show snmp command at the console prompt of the Workgroup Catalyst switch. Ensure the RMON section at the bottom says enabled [default_groups]. If this is not the case, issue the set rmon default_groups enable command and issue the show snmp command again in order to make sure that the default groups are turned on
