ROM Upgrades
Chevy
Hello I am tasked with upgrading our remote switch population and I need some advice as to how I can determine if a ROM version is compatible with an IOS version.
Does anyone have a link/chart for Cisco Switches that helps determine where each IOS version needs a ROM upgrade to function?
Thanks in Advance
Philip D'Ath
Usually all software versions are compatible with all ROMMON versions.
You would need to check the specific ROMMON and switch software release notes.
I have never seen such a table.  Mostly because everything usually works with everything.
Ok Thanks Phil,
If the switches were local, I would be at ease, but the fact that I am 12 to 18 hours away from some the switches causes some concern.
But I am currently in a situation where a 4507 needed a ROM upgrade to be compatible with a newer IOS. I will consult the release guides, but some seem to have it, some dont.
If you want to be sure, upgrade all the ROMMON's first, so you are in a known state to start the switch software upgrades from.
Thanks again for your insight
