ROMMON upgrade/migration fails on ESP40 with Config ASR1006, RP2, SIP40 (redundant)
User404
I have a problem at upgrading the ROMMON of two ESP40.
I posted this comment in an existing thread, but without feedback.
I have some ASR1006 chassis with 2x RP2, 2x ESP40 and 2x SIP40 (2x SPA-10G cards in the SIPs).
During the migration I completely followed the official Cisco instructions: https://www.cisco.com/c/en/us/td/docs/routers/asr1000/release/notes/xe-16-9/asr1000-rel-notes-xe-16-9.html#concept_zdm_2nx_5bb
Especially regarding the recommended ROMMON versions:
Cisco IOS XE ReleaseASR 1000 RP2ASR 1000-SIP40ASR 1000-ESP40
16.9.x16.9(5r)16.3(2r)16.3(2r)
All RPs run on IOS XE 16.9.3 and ROMMON Verion 16.9(5r).
All SIP40s run on ROMMON version 16.3(2r).
Only a few (not all) ESP40 can not be upgraded to 16.3(2r).
The following error message appears:
Target copying rom-monitor image file
cp: omitting directory '/'
md5sum: /: Is a directory
md5sum: /bootflash/EFI/UpdateCapsule/UpdateCapsuleFile.bin: No such file or directory
Does anyone have any idea where the problem is or how to solve it?
Below you can see the whole CLI output:
Router#    sh ver
Cisco IOS XE Software, Version 16.09.03
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Wed 20-Mar-19 08:02 by mcpre
Router# sh platform
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP40       ok                    00:04:27
 0/0      SPA-1X10GE-L-V2     ok                    00:03:05
 0/2      SPA-1X10GE-L-V2     ok                    00:02:57
1         ASR1000-SIP40       ok                    00:04:27
 1/0      SPA-1X10GE-L-V2     ok                    00:03:05
 1/2      SPA-1X10GE-L-V2     ok                    00:02:53
R0        ASR1000-RP2         ok, active            00:04:27
R1        ASR1000-RP2         ok, standby           00:04:27
F0        ASR1000-ESP40       ok, active            00:04:27
F1        ASR1000-ESP40       ok, standby           00:04:27
P0        ASR1006-PWR-AC      ok                    00:03:56
P1        ASR1006-PWR-AC      ok                    00:03:55
Slot      CPLD Version        Firmware Version
0         00200800            16.3(2r)
1         00200800            16.3(2r)
R0        10021901            16.9(5r)
R1        10021901            16.9(5r)
F0        1003190E            16.2(1r)
F1        1003190E            15.3(3r)S
Thanks!
User404
FYI
In our case, the solution was to downgrade the RP2 to get the stubborn ESP40 to the desired ROMMON.
In Step 1: downgrade the RP2 to ROMMON 16.2.1 and the corresponding IOS XE 16.2.x
In Step 2: upgrade to ROMMON 16.3.2 card per card.
Leo Laohoo
Be careful of CSCvo36188.
According to Table 5, ASR 1K with ESP40 should be running a minimum of 16.3(2r).  Only the standby ESP40 is not loaded with this version.  You may need to failover to the secondary ESP40 and run the ROMMON upgrade again.
thanks for the hint!!
Regarding the ROMMON version, 16.3(2r) is the recommended release, the minimum version is 15.0(1r)S according to table 2.
I will try your suggestion and of course let you know if it worked :-)
User404
FYI
