route backup
aissa_alshikh
i have a router configure with RIP and Static route to reach the same Destination , as the static has a low AD , it is preferred, and if the remote side of the static destination is down the RIP it will not take place as the static route still exist in the routing table, how to track the static route and if it is not reachable to be removed and RIP will take place in the routing table.
Yes. Assuming that RIP is learning the same prefix as the static route then if tracking removes the static route then the RIP route will be placed into the active routing table without any extra commands in RIP.
Rick
Rick
Richard Burts
Generally to achieve this you would configure IP SLA to track reachability for the static route.
Rick
Rick
Thank You Richard, but the question is if i configured the IP SLA and track on the Static route,
link ip route 10.10.10.0 255.255.255.0 1.1.1.1 track 10
the static will be removed and i will reach the destination by the RIP without and extra command on RIP config.
Rick
Rick
I am glad that my answer was helpful. Thank you for using the rating system to mark this question as answered. That makes it easier for other readers in the forum to identify discussions that have helpful information.
Rick
Rick
