Route Based S2S IPSEC Slow/Missing Packets?
rtarson98
So I have a PTP S2S IPSEC tunnel created for a location I was able to get the connection up I can ping all the Endpoints in the route okay on both sides. However I noticed connecting to RDP or doing SMB it was SLLLOOOOOW. Or just disconnected due to timeout. I thought maybe it was the DNS. But the dns was reaching but noticed that was having a delay in name resolution.
So then I got down the rabithole of inspecting the packets and doing ping with packet size. I tried with paramters -f and -l. I tested what my largest acceptable packet over IPSEC and noticed that it taps out around 1410. On my FTD the WAN that is connecting the Firepower/Tunnel is set at a MTU of 1500. The extranet device has MSS Clamping with TCP Connection Segment size of 1452 and the MTU is 1500.
I have a feeling it all has to do with the MTU from my readings but if someone thinks other wise I am all ears.
Now to fix Is this something I have to do via the Flexconfig to fix? I read something about adding sysopt_basic. However it looks like it will size all tcp traffic, should I configure to only to size the IPSEC routes only? Also what is the recommended MSS TCP segment size for MTU of 1500 over IPSEC?
22 Replies 22
I am sure it routing issue
can I see RIB in both Peers
also you need to check mac address in wiresharke <<- you can add column for mac source and destination in wiresharke this make it easy for you to check if Peer forward the traffic via correct interface.
MHM
Good morning,
I'm gravitating to that as well but its weird everything looks to be in the right spot.
Here is the Routes on the Extranet Router(I put *** to point it out):
10.0.0.0/24 dev br0 proto kernel scope link src 10.0.0.1
10.0.1.0/24 dev br1001 proto kernel scope link src 10.0.1.1
10.0.2.0/24 dev br1002 proto kernel scope link src 10.0.2.1
10.0.3.0/24 dev br1003 proto kernel scope link src 10.0.3.1
10.0.10.0/24 dev br1010 proto kernel scope link src 10.0.10.1
10.0.60.0/24 dev br1060 proto kernel scope link src 10.0.60.1
10.1.0.0/24 dev vti64 proto static scope link metric 30
10.1.2.0/24 dev vti64 proto static scope link metric 30
10.1.3.0/24 dev vti64 proto static scope link metric 30
10.1.60.0/24 dev vti64 proto static scope link metric 30
10.2.0.0/24 dev vti64 proto static scope link metric 30
***10.2.2.0/24 dev vti73 proto static scope link metric 30***
10.3.0.0/24 dev vti65 proto static scope link metric 30
10.3.2.0/24 dev vti65 proto static scope link metric 30
10.3.3.0/24 dev vti65 proto static scope link metric 30
10.4.0.0/24 dev vti67 proto static scope link metric 30
10.4.2.0/24 dev vti67 proto static scope link metric 30
10.4.3.0/24 dev vti67 proto static scope link metric 30
10.5.0.0/24 dev vti66 proto static scope link metric 30
10.5.2.0/24 dev vti66 proto static scope link metric 30
10.5.3.0/24 dev vti66 proto static scope link metric 30
10.6.0.0/24 dev vti68 proto static scope link metric 30
10.6.2.0/24 dev vti68 proto static scope link metric 30
10.6.3.0/24 dev vti68 proto static scope link metric 30
10.9.0.0/24 dev vti69 proto static scope link metric 30
10.9.2.0/24 dev vti69 proto static scope link metric 30
10.9.3.0/24 dev vti69 proto static scope link metric 30
10.10.0.0/24 dev vti70 proto static scope link metric 30
10.10.2.0/24 dev vti70 proto static scope link metric 30
10.10.3.0/24 dev vti70 proto static scope link metric 30
10.11.0.0/24 dev vti71 proto static scope link metric 30
10.11.2.0/24 dev vti71 proto static scope link metric 30
10.11.3.0/24 dev vti71 proto static scope link metric 30
10.190.0.0/24 dev br1090 proto kernel scope link src 10.190.0.1
10.255.1.0/30 dev vti73 proto kernel scope link src 10.255.1.2
71.115.138.0/24 dev eth0 proto kernel scope link src 71.115.xxx.164
172.16.0.8/29 dev br1072 proto kernel scope link src 172.16.0.10
192.168.1.0/24 dev vti64 proto static scope link metric 30
192.168.61.0/24 dev vti64 proto static scope link metric 30
This is interface vti73
vti73: flags=209<UP,POINTOPOINT,RUNNING,NOARP>  mtu 1419
        inet 10.255.1.2  netmask 255.255.255.252  destination 10.255.1.2
        inet6 fe80::200:5efe:4773:8aa4  prefixlen 64  scopeid 0x20<link>
        tunnel   txqueuelen 1000  (IPIP Tunnel)
        RX packets 12  bytes 838 (838.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 12  bytes 1567 (1.5 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
On the FTD side now
Gateway of last resort is 74.106.X.1 to network 0.0.0.0
S*       0.0.0.0 0.0.0.0 [20/0] via 74.106.X.1, ISP-WAN
S        10.0.0.0 255.255.255.0 [5/0] via 10.255.1.2, CIC-SVTI
S        10.0.2.0 255.255.255.0 [5/0] via 10.255.1.2, CIC-SVTI
S        10.0.3.0 255.255.255.0 [5/0] via 10.255.1.2, CIC-SVTI
S        10.0.60.0 255.255.255.0 [5/0] via 10.255.1.2, CIC-SVTI
C        10.2.2.0 255.255.255.0 is directly connected, Supply-Wired-Clients
L        10.2.2.1 255.255.255.255 is directly connected, Supply-Wired-Clients
S        10.3.0.0 255.255.255.0 [5/0] via 10.255.2.2, DWT-SVTI
S        10.3.2.0 255.255.255.0 [5/0] via 10.255.2.2, DWT-SVTI
S        10.3.3.0 255.255.255.0 [5/0] via 10.255.2.2, DWT-SVTI
V        10.4.0.0 255.255.255.0
           connected by VPN (advertised), ISP-WAN
V        10.4.2.0 255.255.255.0
V        10.4.3.0 255.255.255.0
V        10.6.0.0 255.255.255.0
V        10.6.2.0 255.255.255.0
V        10.6.3.0 255.255.255.0
V        10.7.0.0 255.255.255.0
C        10.254.0.0 255.255.255.248
           is directly connected, Supply-Ubiquiti-MGMT
L        10.254.0.1 255.255.255.255
C        10.255.1.0 255.255.255.252 is directly connected, CIC-SVTI
L        10.255.1.1 255.255.255.255 is directly connected, CIC-SVTI
C        10.255.2.0 255.255.255.252 is directly connected, DWT-SVTI
L        10.255.2.1 255.255.255.255 is directly connected, DWT-SVTI
C        10.255.255.1 255.255.255.255 is directly connected, S2S-Loopback
C        74.106.X.0 255.255.255.0 is directly connected, ISP-WAN
L        74.106.X.118 255.255.255.255 is directly connected, ISP-WAN
C        192.168.1.0 255.255.255.0 is directly connected, Legacy-Subnet-192
L        192.168.1.1 255.255.255.255 is directly connected, Legacy-Subnet-192
 Here is the screenshot of the packet capture showing the DestMAC
No Response
The one with a response:
Hi Friend
sorry for late reply
are above correct ? how same subnet is learn from ISP-WAN and VTI ??
this make issue sure
MHM
After support calls with cisco and ubiquiti. I took another glimpse. Turned out to be LACP config issue. I thought LACP On in cisco world meant LACP negotation. My Switching LACP to active corrected everything crazy stuff literally a dropdown.
Also Here is the only route I have in FMC per Cisco documentation for that tunnel.
Internal Subnet selected include
10.0.0.0/24
10.0.60.0/24
10.0.2.0/24
10.0.3.0/24
With a metric of 4. The General WAN traffic has metric 20
Joseph W. Doherty
The usual Cisco recommendation for crypto is to use a MTU and MSS, 1,000 less.  On Cisco router interfaces, such as their VTIs, this is often accomplished by setting IP MTU 1400 and IP TCP ADJUST-MSS 1360.
Now is there a way to just do this on the VTI. Or do I have to do on the uplink. Cause if that’s the case I most likely would want second uplink for tunnels? Leave my regular traffic with mtu of 1500
Not familiar with your Firepower, but on Cisco routers, you only need to apply those commands on the VTI.
