Route Filtering Regular Expression
nikgupt4
I am little confused about using the exact RegEx for route filtering.
here is the BGP topology
R1(IDMZ)---------ebgp 64000------FIREWALL-----ibgp 64600-----R2(EDMZ)
R1 is sending default to R2 and receiving only R2 Local and its connected AS routes(lets say 64999 only). No other route from EDMZ is allowed.
so how would be my AS-PATH access list at R1 with RegEx
2 Accepted Solutions
Muhammad Awais Khan
The ACL to allow routes originated from R2 at 64999 and  learned through 646000 and 64000.
ip as-path access-list 10 permit ^64000_64600_64999$
Georg Pauwen
it is unclear in which AS your R1 router is, is it 64000 ?
If you want to receive only routes from 64600 and neighbors directly attached to 64600, you can use the AS PATH access list below:
ip as-path access-list 1 permit ^64600_[0-9]*$
This will allow 64600 and any neighbors directly attached to 64600...
ip as-path access-list 1 permit ^64600_64999$
This will allow only routes from 64600 and the neighbor 64999 directly attached to 64600...
8 Replies 8
Muhammad Awais Khan
R2 is running 64600 with Firewall (iBGP) and has downstream AS connected as 64999. I want only local routes of R2 and connected AS routes at R1. No other routes except 64600 and 64999 should be in BGP table of R1
Then my above ACL should be fine as it will allows the route originated from 649999.
If R1 is in AS 64000, this access list will block all routes:
That is because no route will ever match, as it has its own AS (64000) in the path.
Georg Pauwen
Yes R1 is 64000 with FW. R2 64600 and its connected AS i.e 64999 should be seen in R1 . Moreover 64999 is prepended 4 times while reaching R1 IDMZ. no other AS should reach R1.
so your RegEx can be used ?
Georg Pauwen
actually, I think your AS path list needs two lines:
ip as-path access-list 1 permit ^64600$
If you just use the second line, you won't get networks originated in AS 64600, but only networks that originate in AS 64999 and that traverse AS 64600.
