Route Leaking between VRF's on same router(with MPLS)
Jason Mann
Actually have two questions on the below config. We are trying to share a single route between two vrf's on the same router. The below config is not workig. Also does an export map pertain to the whole vrf or just the rt is if it is set in the route-map? Thanks!
ip vrf PUB
rd 20:7
export map PUBvrf-export
route-target export 20:7
route-target import 20:7
route-target import 10:10
ip vrf USERS
rd 20:2
export map STATEvrf-export
route-target export 20:2
route-target import 20:2
route-target import 10:99
interface FastEthernet0/1.10
description USERS VRF
encapsulation dot1Q 10
ip vrf forwarding USERS
ip address 10.144.230.1 255.255.255.0
interface FastEthernet0/1.99
description PUB VRF
encapsulation dot1Q 99
ip vrf forwarding PUB
ip address 172.26.2.1 255.255.255.0
router ospf 3482
router-id 10.194.184.20
log-adjacency-changes detail
auto-cost reference-bandwidth 100000
area 500 authentication message-digest
area 500 stub
network 10.0.0.0 0.255.255.255 area 500
router bgp XXXX
no synchronization
bgp log-neighbor-changes
neighbor ALL_RR peer-group
neighbor ALL_RR remote-as XXXX
neighbor ALL_RR update-source Loopback0
neighbor ALL_RR send-community both
neighbor 10.194.184.1 peer-group ALL_RR
neighbor 10.194.184.2 peer-group ALL_RR
neighbor 10.194.184.3 peer-group ALL_RR
no auto-summary
address-family vpnv4
neighbor 10.194.184.1 activate
neighbor 10.194.184.2 activate
neighbor 10.194.184.3 activate
exit-address-family
address-family ipv4 vrf USERS
redistribute connected
no synchronization
exit-address-family
address-family ipv4 vrf PUB
no synchronization
exit-address-family
ip prefix-list PUBvrf-nets seq 5 permit 172.16.2.10/32
ip prefix-list USERSvrf-nets seq 5 permit 10.144.230.200/32
route-map PUBvrf-export permit 10
match ip address prefix-list PUBvrf-nets
set extcommunity rt 10:99 additive
route-map USERSvrf-export permit 10
match ip address prefix-list USERSvrf-nets
set extcommunity rt 10:10 additive
Jason,
you could configure a static host route for each host and then redistribute the static route in the VRF context as follow:
ip route vrf USERS 10.144.230.200 255.255.255.255 FastEthernet0/1.10 10.144.230.200
router bgp xxx
redistribute static
The other prefix (172.26.2.10) does not seem to be directly connected, so the static route will be accordingly.
Harold Ritter
Jason,
Looking at the prefix-lists, the only routes you allow are 172.16.2.10/32 (vrf PUB) and 10.144.230.200/32 (vrf USERS). Where do they come from, as you only redistribute the connected routes in the VRF context under the BGP process and none of the connected routes (10.144.230.0/24 and 172.26.2.0/24) match these prefixes.
That is what I was afraid of. What has happened is that 172.26.2.10 needs to talk with 10.144.230.200. Both of the user's intiate the conversation. The PUB vrf runs to a firewall back at our main building and the USER vrf runs to an aggregate router in our main building. We are trying to alleviate the hops that these two users take to talk to each other but we don't want to distribute all of the routes between the two VRF's so that is why we put in the export maps. Is there a way to export a single host so that each of the vrf's will know it about the hot but not the rest of the network? Thanks!
Jason,
router bgp xxx
redistribute static
