Route Leaking issues between VRFs
palani2010
3 Accepted Solutions
Router ID must config manually.
Add router ID then check leaking route
Hi @palani2010 ,
What IOS version are you using? I cut and pasted your configuration in 15.9(3)M4 and it works.
Router#sh ip route vrf TEST_A
Routing Table: TEST_A
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.10.0/24 is directly connected, Loopback10
L 192.168.10.1/32 is directly connected, Loopback10
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.20.0/24 is directly connected, 00:03:33, Loopback20
L 192.168.20.1/32 is directly connected, Loopback20
Router#sh ip route vrf TEST_B
Routing Table: TEST_B
B 192.168.10.0/24 is directly connected, 00:03:40, Loopback10
C 192.168.20.0/24 is directly connected, Loopback20
Router#
Hi @MHM Cisco World ,
In the test I just ran, it gives me the error message that the RID is not configured, but leaking still works despite of that message:
Router(config-router)#!
*Sep 19 12:54:41.826: %BGP-4-NORTRID: BGP could not pick a router-id. Please configure manually.
7 Replies 7
Hello
What issue are you experiencing?
Kind Regards
Paul
palani2010
Route leaking between VRFs are not working.
ROUTE_LEAKING>sh ip route vrf TEST_B
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
ROUTE_LEAKING>sh ip route vrf TEST_A
Can you share config?
palani2010
Attached Configuration for your reference.
Below are output for your reference
Hi @palani2010 ,
Router#
