Route Leaking?
CiscoBrownBelt
Level 6
Level 6
If I have a  Router2 interface that is assigned to a VRF on g1, and I want to be able to still reach IP addresses and or devices beyond the VRF interface towards the right, what is the best way to do route leakes between the VRF assigned interface and other IPs on the router so Router 1 can still reach thos and R3, R4, etc.?
Router1-------------(gi1/VRF Blue 10.1.1.1-ROUTER2-gi2 20.1.1.1)-----------------Router3, >>>R4>>>R5, etc.
what route leaking do you have configured so far ? Post the running configs of R1 and R2...
Hello
Append a default route into the vrf rib to point to the global route table of the router
ip roite 0.0.0.0 0.0.0.0 g1 10..1.1.x  global
Kind Regards
Paul
Great. What IP address would I use to point to? The 10.1.1.1 is the IP of the VRF interface.
Hello
the outside interface next hop ip address 20.1.1.2?
you may also need to tmake your own rtr aware of the vrf host for return traffic
ip route 10.1.1.1 255.255.255.255 gig1
Kind Regards
Paul
