HELP with ACL and PAT
Good Evening all I need help. Im trying to deny Manchester site from talking to ISP disable PAT on its addreses. The site itself can still talk to Cambridge and London but not ISP. of course it can bar done by not defining default route on Manchester router but it needs to be done using acl I tried lots of option. please see the graph and full network settings:
here are the working configs for your routers (changes/additions marked in bold). I took the static routes out, for the sake of simplicity. The main problem was a missing 'ip nat inside' interface on one of the serials of the Cambridge router. Also, in order to block ICMP, in Packet Tracer you apparently have to explicitly specify it...
ManchesterR
Current configuration : 1674 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ManchesterR
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.4.1
ip dhcp excluded-address 192.168.8.1
ip dhcp pool Finance
network 192.168.0.0 255.255.252.0
default-router 192.168.0.1
ip dhcp pool Support
network 192.168.4.0 255.255.252.0
default-router 192.168.4.1
ip dhcp pool ExternalSales
network 192.168.8.0 255.255.252.0
default-router 192.168.8.1
no ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX1524X76P-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.0.1 255.255.252.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.4.1 255.255.252.0
interface GigabitEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.8.1 255.255.252.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 172.16.3.2 255.255.255.252
clock rate 2000000
interface Serial0/0/1
ip address 172.16.2.2 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 3.3.3.3
log-adjacency-changes
network 172.16.2.0 0.0.0.3 area 0
network 172.16.3.0 0.0.0.3 area 0
network 192.168.0.0 0.0.3.255 area 0
network 192.168.4.0 0.0.3.255 area 0
network 192.168.8.0 0.0.3.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
CambridgeR
Current configuration : 2627 bytes
version 15.1
hostname CambridgeR
ip dhcp excluded-address 192.168.18.1
ip dhcp excluded-address 192.168.19.1
ip dhcp excluded-address 192.168.20.1
network 192.168.19.0 255.255.255.0
default-router 192.168.19.1
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
network 192.168.18.0 255.255.255.0
default-router 192.168.18.1
no ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX1524N3GZ-
no ip address
duplex auto
speed auto
ip address 192.168.18.1 255.255.255.0
ip nat inside
ip address 192.168.19.1 255.255.255.0
ip nat inside
ip address 192.168.20.1 255.255.255.0
ip nat inside
ip address 200.0.113.1 255.255.255.240
ip access-group 101 in
ip nat outside
duplex auto
speed auto
ip address 172.16.1.2 255.255.255.252
ip nat inside
ip address 172.16.3.1 255.255.255.252
ip nat inside
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 2.2.2.2
network 192.168.18.0 0.0.0.255 area 0
network 192.168.19.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
network 172.16.1.0 0.0.0.3 area 0
network 172.16.10.0 0.0.0.3 area 0
network 200.0.113.0 0.0.0.15 area 0
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip classless
access-list 1 permit 192.168.0.0 0.0.3.255
access-list 1 permit 192.168.4.0 0.0.3.255
access-list 1 permit 192.168.8.0 0.0.3.255
access-list 1 permit 192.168.18.0 0.0.0.255
access-list 1 permit 192.168.19.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 192.168.12.0 0.0.1.255
access-list 1 permit 192.168.14.0 0.0.1.255
access-list 1 permit 192.168.16.0 0.0.1.255
access-list 101 deny icmp 192.168.0.0 0.0.3.255 200.0.113.0 0.0.0.15
access-list 101 deny icmp 192.168.4.0 0.0.3.255 200.0.113.0 0.0.0.15
access-list 101 deny icmp 192.168.8.0 0.0.3.255 200.0.113.0 0.0.0.15
access-list 101 deny ip 192.168.0.0 0.0.3.255 200.0.113.0 0.0.0.15
access-list 101 deny ip 192.168.4.0 0.0.3.255 200.0.113.0 0.0.0.15
access-list 101 deny ip 192.168.8.0 0.0.3.255 200.0.113.0 0.0.0.15
line con 0
line aux 0
line vty 0 4
login
end
LondonR
Current configuration : 1665 bytes
version 15.1
hostname LondonR
ip dhcp excluded-address 192.168.12.1
ip dhcp excluded-address 192.168.14.1
ip dhcp excluded-address 192.168.16.1
network 192.168.12.0 255.255.254.0
default-router 192.168.12.1
network 192.168.14.0 255.255.254.0
default-router 192.168.14.1
network 192.168.16.0 255.255.254.0
default-router 192.168.16.1
no ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX1524K05Q-
no ip address
duplex auto
speed auto
ip address 192.168.12.1 255.255.254.0
ip address 192.168.14.1 255.255.254.0
ip address 192.168.16.1 255.255.254.0
no ip address
duplex auto
speed auto
shutdown
ip address 172.16.1.1 255.255.255.252
clock rate 2000000
ip address 172.16.2.1 255.255.255.252
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 1.1.1.1
network 192.168.12.0 0.0.1.255 area 0
network 192.168.14.0 0.0.1.255 area 0
network 192.168.16.0 0.0.1.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
ISP
version 15.1
hostname ISP
ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX1524S463-
no ip address
duplex auto
speed auto
shutdown
ip address 200.0.113.2 255.255.255.240
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 200.0.113.1
line con 0
line aux 0
line vty 0 4
login
28 Replies 28
post the zipped .pkt file...
it is unclear what you are trying to accomplish. Which IP addresses is the Manchester site not supposed to talk to ?
on the Cambridge router, add the access list below and apply it to the interface going towards the ISP:
access-list 101 permit ip any any
ip nat outside
duplex auto
Manchester can still talk to ISP unfortunately. PAT is also only increasing misses no hits
can you post the traceroute results from a client on the Manchester network towards the ISP ?
Tracing route to 200.0.113.2 over a maximum of 30 hops:
1 0 ms 0 ms 0 ms 192.168.0.1
2 0 ms 0 ms 0 ms 172.16.3.1
3 30 ms 1 ms 0 ms 200.0.113.2
Trace complete.
ACL doesn't seem to work
the access list should block this. Post the full configuration of the Cambridge router with the access list applied...
any of these does the blocking:
ip access-list standard Deny-Manchester
remark Allow traffic from 192.168.18.0/24
remark Allow traffic from 192.168.19.0/24
remark Allow traffic from 192.168.20.0/24
remark Allow traffic from 192.168.12.0/23
remark Allow traffic from 192.168.14.0/23
remark Allow traffic from 192.168.16.0/23
remark Do not allow traffic from 192.168.0.0/22
deny 192.168.0.0 0.0.3.255
remark Do not allow traffic from 192.168.4.0/22
deny 192.168.4.0 0.0.3.255
remark Do not allow traffic from 192.168.8.0/22
deny 192.168.8.0 0.0.3.255
ip nat outside
duplex auto
the problem starts when it comes to PAT as when any access list is applied the PAT does not translate any addreses. its like I can't have PAT and ACL on the same interface
here is the config
Building configuration...
Current configuration : 3768 bytes
version 15.1
service password-encryption
security passwords min-length 8
hostname CambridgeR
login block-for 100 attempts 3 within 100
enable secret 5 $1$mERr$UNr.E/7yZJIkFYsWULMer0
ip cef
no ipv6 cef
username manager password 7 08027E1E3C2D202532
license udi pid CISCO2901/K9 sn FTX1524WDFG-
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat outside
duplex auto
speed auto
ip nat inside
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 2.2.2.2
router rip
ip classless
ip route 192.168.12.0 255.255.254.0 172.16.1.1
ip route 192.168.14.0 255.255.254.0 172.16.1.1
ip route 192.168.16.0 255.255.254.0 172.16.1.1
ip route 192.168.0.0 255.255.252.0 172.16.3.2
ip route 192.168.4.0 255.255.252.0 172.16.3.2
ip route 192.168.8.0 255.255.252.0 172.16.3.2
ip route 0.0.0.0 0.0.0.0 200.0.113.2
ip access-list extended sl_def_acl
deny tcp any any eq telnet
deny tcp any any eq www
deny tcp any any eq 22
permit tcp any any eq 22
banner motd ^C!!! Unauthorised access or use of this equipment is prohibited.If you are not authorised to access this system, terminate this session immediately otherwise the legal action can be taken against you. !!!^C
line con 0
exec-timeout 5 20
login local
line aux 0
exec-timeout 5 20
login local
line vty 0 4
exec-timeout 5 20
login local
end
CambridgeR#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CambridgeR(config)#access-list 101 deny ip 192.168.0.0 0.0.3.255 200.0.113.0 0.0.0.15
CambridgeR(config)#access-list 101 deny ip 192.168.4.0 0.0.3.255 200.0.113.0 0.0.0.15
CambridgeR(config)#access-list 101 deny ip 192.168.8.0 0.0.3.255 200.0.113.0 0.0.0.15
CambridgeR(config)#access-list 101 permit ip any any
CambridgeR(config)#!
CambridgeR(config)#interface GigabitEthernet0/1
CambridgeR(config-if)#ip address 200.0.113.1 255.255.255.240
CambridgeR(config-if)#ip nat outside
CambridgeR(config-if)#ip access-group 101 in
CambridgeR(config-if)#duplex auto
CambridgeR(config-if)#do show run
Current configuration : 4027 bytes
version 15.1
hostname CambridgeR
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat outside
duplex auto
speed auto
ip nat inside
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 2.2.2.2
router rip
ip classless
line con 0
exec-timeout 5 20
login local
line aux 0
exec-timeout 5 20
login local
line vty 0 4
exec-timeout 5 20
login local
--More--
this is getting a bit confusing. The networks you are blocking:
are not being translated because you did not specify them in access list 1 (which determines the NAT sources)...
Anyone?
ManchesterR
version 15.1
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
clock rate 2000000
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 3.3.3.3
ip classless
line con 0
line aux 0
line vty 0 4
login
end
CambridgeR
version 15.1
hostname CambridgeR
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat outside
duplex auto
speed auto
ip nat inside
ip nat inside
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 2.2.2.2
ip classless
line con 0
line aux 0
line vty 0 4
login
end
LondonR
version 15.1
hostname LondonR
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 1.1.1.1
ip classless
line con 0
line aux 0
line vty 0 4
login
end
ISP
version 15.1
hostname ISP
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
Working file attached...
