route-map clause action with match statements - is this true?
kennethsali
Please let us know if this is true or false.
When you have a route-map defining a clause with a deny statement on it and have an access-list that does not define anything, this route-map clause will not have any effect on the routes
eg.
route-map cisco deny 10
match ip address cisco
route-map cisco permit 20
set metric 20
ip access-list extended cisco
##implicit deny all##
This is because there is an implicit deny on the access-list and logically that will cause all traffic through the sequence to go on the next clause 20 and set metric to 20 for all routes.
However, if you have a similar scenario but do not actually define the access-list in cisco IOS 'ip access-list extended cisco' then the route-map logic will ignore that match statement and implicitly deny everything.
set metric 20
Edison Ortiz
You are correct.
Interfaces to redistribute with route-map
interface Loopback0
interface Loopback1
ip address 192.168.2.1 255.255.255.0
route-map information and ACL per your config
ip access-list standard cisco
permit 192.168.1.0 0.0.0.255
set metric 20
I'm using OSPF for this test
router ospf 1
log-adjacency-changes
redistribute connected subnets route-map cisco
network 10.0.0.1 0.0.0.0 area 0
Let's observe the OSPF database
sh ip os data
OSPF Router with ID (192.168.2.1) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
192.168.2.1 192.168.2.1 250 0x80000002 0x0053F8 1
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
192.168.2.0 192.168.2.1 94 0x80000001 0x00FFC8 0
192.168.2.0/24 is being redistributed per the route-map.
Now, let's remove the ACL and check the database:
#conf t
Enter configuration commands, one per line. End with CNTL/Z.
(config)#no ip access-list standard cisco
(config)#do show ip os data
192.168.2.1 192.168.2.1 349 0x80000002 0x0053F8 1
(config)#
HTH,
__
Edison.
