SFP module is not detecting in Cisco 3845
senthil.gabriel
Can anyone tell me what could be the issue with SFP(GLC-LH-SM ) which is supported by this platform is not getting dedected.
IOS :c3845-advipservicesk9-mz.124-10a.bin
the same is working in Cisco Switches.
spremkumar
Level 9
Level 9
Can you post the output of the show version here ?
Also are you getting any error logs on the router.
Do make use of the following links to check out the compatible IOS.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
Edison Ortiz
Only SFPs made by Cisco are supported on the Cisco 3800 Series. SFPs from oher vendors will not be enabled.
Is that the case here?
HTH,
__
Edison.
