Route map help please (1811)
rygar1234
Need advise/help please
Ip 70.x.x.x = Local Users / Backup Email ip
Ip 69.x.x.x = Email / Local users Backup ip
Everything seems to be working almost ok. The problem I am having is that the router defaults to the 70.x.x.x ip for Email. Here is part of the config file.
I think the problem is with my lst command line.
track timer interface 5
track 10 rtr 1 reachability
delay down 15 up 10
track 20 rtr 2 reachability
delay down 15 up 10
ip route 0.0.0.0 0.0.0.0 FastEthernet0 70.x.x.x track 10
ip route 0.0.0.0 0.0.0.0 FastEthernet1 69.x.x.x 200 track 20
ip nat inside source route-map cable-nat interface FastEthernet0 overload
ip nat inside source route-map dsl-nat interface FastEthernet1 overload
ip nat inside source static tcp 192.168.0.15 25 69.x.x.x 25 route-map exchange extendable
ip nat inside source static tcp 192.168.0.15 25 70.x.x.x 25 route-map exchange extendable
access-list 111 permit tcp host 192.168.0.15 any eq smtp
route-map exchange permit 10
match ip address 111
set ip next-hop verify-availability 69.x.x.x 1 track 20
If i add this line would it be correct?
route-map exchange permit 20
set ip next-hop verify-availability 70.x.x.x 2 track 10
OR
Thank you!
6 Replies 6
Hi Stathis,
I'm not sure what is exactly your problem.But I would use the command as follows:
The router will send SMTP traffics out of the fastethernet1 interface if it is UP. If not then send to the fastethernet0 interface for backing up. ##If It's up as well ;-)
Hopes this helps
Thot
Thx Thot
The problem is that when I receive email it defaults to fastethernet0 70.x.x.x and not the 69.x.x.x in fact port 25 on the 69.x.x.x is closed. fastethernet0 70.x.x.x port 25 works fine.
If i simulate a fail for 70.x.x.x then 69.x.x.x port 25 works fine.
Somehow i have to reverse it if its possible.
Thank you
Hi Stathis,
Please correct me if I'm wrong. You meant that you receive the e-mails from 70.x.x.x.So what's going on?
I want to send an email to you.I have to solve your MX-Record first. I meant your domain.ISP tells me hey! sathis@abcd.com please go to 70.x.x.x.
Please tell me what's your exact public ip address(high priority) using for SMTP traffics(Inbound!).
Is that your problems? if so,ISP will be involved I guess!
Hopes this helps
Thot
Sorry Thot let me try again. The router is not live yet i plug it in after work hours to test it.
70.x.x.x Fa0 = Local users internet - Backup for exchange
69.x.x.x Fa1 = Exchange - Backup for Local Users
With my current configuration when i try to telnet to port 25 or access port 25 on the 69.x.x.x Fa1 i get denied BUT 70.x.x.x Fa0 works fine.
If I simulate fail on 70.x.x.x then 69.x.x.x works fine which is very cool but its reversed. I want 69.x.x.x as first email ip and 70.x.x.x as backup.
The isp is set to sent to 69.x.x.x first and if it fails it will try 70.x.x.x
Thank you
Hi Stathis,
I think you need to use a "sh ip nat trans" command and see what happens when you telnet tcp/25 on the 69.x.x.x address. Is there an interesting NAT entry on it?
Using a "netstat -an" command on the server(192.168.0.15).Is there any connections from the outside using TCP/25? Is the status "established" or "TimeOut" or nothing?
Is there any devices between the router and the server Aka a firewall?
Hopes this helps
Thot
Thx Thot
I will check but i believe the router somehow is blocking port 25 as it thinks the 69.x.x.x is the backup ip.
Its allowing port 25 on the 70.x.x.x to receive incoming email if I unplug it its allowing port 25 on 69.x.x.x to receive email.
I will open a support call to see if they can help me.
Thx again Thot!
