Route Map help
nocret808
i am going to be installing our new ASA and would like to add this to my 6509 Core which currently configured for policy route map. need second eyes if this is going to work for me. I am going to add the following on top of what i currently have in my core (attachment is what's going to look like after i added the VPN_ASA below). please help.
redistribute static route-map VPN_ASA
access-list 20 permit 192.168.40.0 0.0.0.255
route-map VPN_ASA permit 20
match ip address 20
shivlu jain
Level 5
Level 5
it will permit only 192.168.40.0/24 rest will be denied. If you want to permit the rest one or any other network then add one more statement given below
route-map VPN_ASA permit 30
regards
shivlu jain
thanks. so what you are saying is all other such "route-map Static->eigrp permit 10 is not permitted unless i add "route-map VPN_ASA permit 30?
pls let me know.
thanks
hi nathan,
I'm not clear about your question. Are you trying to redistribute "ip route 192.168.40.0 255.255.252.0 10.192.168.0.130" into eigrp by using route-map. Right?
Why are you using two redistribute-statics? It wouldn't be allowed. And I think the the second statement will not work anyway. You have to assign metrics there.
Just combine them to be one statement. It depends on what you've decided to implement.
Toshi
