Route-map into BGP, with the same AS
iacastillop
hello, i have this configuration at three routers running BGP,
ROUTER CORE
router bgp 10
 bgp log-neighbor-changes
 neighbor 10.10.10.1 remote-as 500
 neighbor 11.11.11.1 remote-as 500
 auto-summary
ROUTER 1
router bgp 500
 neighbor 20.20.20.20 remote-as 6147
 neighbor 10.10.10.2 remote-as 10
ROUTER 2
router bgp 500
 neighbor 30.30.30.30 remote-as 6147
 neighbor 11.11.11.2 remote-as 10
I try to send some traffic using the router 1 and another traffic using router 2, How can i do it?
Thanks in advance for the help.
Jose Jara
Level 3
Level 3
In order to have a better idea of the scenario and what you would like to achieve, please, give us more information. Do you manage these three routers ? Do you want to implement load sharing between Core Router and Router 1 and 2 ?
If you want to do load sharing, you could do it that way:
-  From Core Router to Router 1 and 2: assuming that Core router is receiving the same prefixes with the same attributes from both peers, you could implement maximum-paths 2. This will load share the outgoing traffic from AS 10 to AS 500 between both routers.
- From Router 1 and 2 to Core: you may advertise different prefixes per neighbor. For example, if you are advertising an /24 from AS 10, you may advertise the /24 and the first /25 to Router-1 and the /24 and the second /25 to Router-2. This will load share the incoming traffic from AS 500 towards AS 10.
Best Regards,
Jose.
Jose Jara
Level 3
Level 3
Best Regards,
Jose.
Thank you very much for the answer, i have the administration for the three routers, my case is just as the first one way you say, i implemented maximum-path 2, and load sharing works, also i implement a route-map, to send a specific traffic using Router 1. To implement the route-map i used this example,
http://www.digitaltut.com/route-policy-based-routing-sim
Thanks José.
