route-map logical AND
jackie_gx
i want to config route-map with AND logical to match 2 list of ACL. But when i enter the config like this :
route-map TEST permit 10
match ip address 111
match ip address 112
it show the command like this:
match ip address 111  112
How can i config a logical AND under the route-map?
11 Replies 11
that is already logical AND, I suppose.
not that logical OR?
your're right, only several match's are processed as AND, but inside of a match command the entries are OR'ed.
It's a good question, I don'T have an idea how to do it.
but may be you could  explain  why do you need two ACL to be ANDed?
We are in the progess to migrate braches. The branches not migrate yet will flow as normal, the ane already been migrated will be foward to a vrf. The traffic will be commming inbound at the interface. And the thing is, the source is of the ip is always the same, but the destination is diff cos is point to the branches ip. So insted of all huge ammount of ACL when doing the migration, i plan to write 2 ACL, one to match the source and other one to match the destination ip. Since the source is always the same, i just need to add the Dest ACL during the migration.
it seems to be that the only possibilities to do it - to use a  ACL with a same source and different destinations.
Or may be you can use e.g. a tag for cirtain branchs prefixes and then use ACL and "matc tag" in the same route-map.
think i found the way by using "continue", it will go down the follow sequence even it match.
Cool! Thank you for the update. I've read about "continue" but haven't tested yet.
In my case continue doesn't work, I try to deny if any of these routes are not on the table
access-list 20 permit 157.10.36.0 0.0.0.255
access-list 21 permit 157.10.37.0 0.0.0.255
no route-map INTERFACES
route-map INTERFACES permit 10
match ip address 20
continue
route-map INTERFACES permit 20
match ip address 21
OR
match ip address 20
continue 20
match ip address 21
If I shut down one interface it keeps permitting it and that's not the point of it
I don't think two ACLs with AND could be used within on route-map entry.
But it might be worth to use object-groups to create one ACL instead of a huge combinations of the existing ACLs?
See
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_acl/configuration/15-2mt/sec-object-group-acl.html#GUID-BE5C124C-CCE0-423A-B147-96C33FA18C66
for details.
HTH,
Milan
When all the conditions are verified, then you are aware of an logical AND operation. In QoS match-all would be an AND
Hope this help
Alessio
the question is how to make a logic AND with a route map no what a logic AND is.
