Problem with VLAN 2 on Cisco 877 Router
sivaalthi85
Hi Friends,
One of my client has cisco 877 router on which we have VLAN1 which is   10.0.140.1 and this router is connected to firewall on port 0.
the firewall ip is 10.0.140.2
the cisco 877  has got total 4 ports.
Now my client wants me to create a different subnet for the lan directly from the router, so it shouldn't go through the firewall.
So I have choosed port 2 for this and configured interface vlan 2 with 172.16.15.1
Problem is Vlan 1 got access to the internet but vlan 2 is not getting internet at all. Any help would be highly appreciated.
Below is the config:
hostname Internet
boot-start-marker
boot-end-marker
logging buffered 4096
logging console critical
enable secret 5 $1$g364$22w6N7fgr65zx3z6E9CUqCli/
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone GMT 0
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
no ip bootp server
no ip domain lookup
username xxxx password 7 xxxx
archive
log config
  hidekeys
interface ATM0
description $ES_WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface Vlan1
ip address 10.0.140.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
interface Vlan2
ip address 172.16.15.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password 7 xxxx
ppp pap sent-username xxx password 7 yyyy
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.0.0.0 255.255.255.0 10.0.140.2
ip route 172.16.15.0 255.255.255.0 172.10.15.2
ip http server
ip http port 8080
no ip http secure-server
ip nat inside source static 10.0.140.2 interface Dialer0
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password 7 0001955
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
ntp clock-period 17175070
ntp server 4.2.2.2
end
sivaalthi85
I added Below lines and everything working fine.
ip access-list extended NAT
permit ip 172.16.15.0 0.0.0.255 any
ip nat inside source list NAT interface Dialer0 overlaod
