Route Map on WCCP engine interface
Torey Geisbert
How will using PBR on a router interface that is directly connected to an optimizer using wccp work.
Basically I want send traffic from one network to the optimizer via wccp. And then apply a PBR as it comes back from the optimizer.
I have this set up and there are some matches on the routemap acl entries but I am afraid there may be some asymmetic routing going on and my optimization service won't come up.
Can you policy route traffic on the return from a wccp engine/optimizer?
Does gre get in the way?
rrcorleto
I have been working for a few months with the same problem, and the only work around i have found is to redirect traffic to the optimizer with PBR as well; for what I see, if WCCP kicks in the route map won't work any more. So get rid of the PBR or work everything with PBR.
