route-map permit {match tag}
NAGISWAREN2
Hi all,
I have some problem on route filtering.
I have two sites have OSPF neighbor relationship. I would like to filter OSPF route by route tag. I want to only permit only specifi route tag, and deny the rest.
SITE A <--OSPF--> SITE B
SITE B router have redistributed static route into OSPF process with route tag 200. Below is the command i applied in SITE A router.
route-map filter permit 10
match tag 200
route-map filter deny 20
router ospf 100
distribute-list route-map filter in
But, once i applied the distribute-list command, i lost all routing learned from SITE B router. Before apply the command, i did "sho ip route x.x.x.x" in SITE A(for the matching prefix) , i could see the route tag as "200" . But why it block all the subnets from SITE B router?
I did reverse testing, as below, and it works as suppose. Why its not working the other way ?
route-map filter deny 10
match tag 200
route-map filter permit 20
Nagis
Regards, Nagis
2 Accepted Solutions
Rolf Fischer
Level 9
Level 9
Nagis,
if my understanding is correct, the router at site B is an ASBR and you want to filter out certain external OSPF routes on the router at site A based on tags.
All the external routes will be in the LSBD, the distribute-list in command just defines which routes will be installed in the local routing table.
In order to install external routes, the ASBR has to be reachable; I suppose that your route-map filters out ASBR connectivity too.
Could you check that (show ip ospf border-routers) and make sure that router A knows how to reach the ASBR (router B)?
Rolf
Ok, I think this is causing the problem:
Forward Address: 192.168.35.254
OSPF is enabled on the corresponding interface on router B and the forwarding address is set to non-zero for path-optimization.
So you could either make sure that this network is reachable from router A (changing the route-map) or, if suitable, you could disable OSPF on this network on router B.
Link: Common Routing Problem with OSPF Forwarding Address
Rolf
9 Replies 9
Rolf Fischer
Level 9
Level 9
Nagis,
Rolf
Hi Rolf,
Yes, SITE B router is ASBR. Fyi, both router is connected via GRE tunnel. After applied the command, i still can see route to reach SITE B router, as its directly connected subnet. But still cant see any route from SITE B router. Any other mistakes?
Nagis
Regards, Nagis
Can you see Site B's LSAs in the LSDB of router A (show ip ospf database adv-router )?
Hi Rolf,
Yes. As shown below
                Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
192.168.38.0    3.3.3.3         1663        0x8000000A 0x003761 2000
192.168.39.0    3.3.3.3         1663        0x8000000E 0x00246F 2000
Nagis
Regards, Nagis
Nagis,
match tag 200
router ospf 100
Looks like the routes are tagged with 2000 but you filter on tag 200?
Rolf
[EDIT]:
If this was just a typo, could you please post the output of "show ip ospf database external 192.168.38.0"? Perhaps we have a connectivity issue with a non-zero forwarding address.
HI Rolf,
Yes , it was type. Actual Tag is 2000.
Show command before apply distribute-list
RTR#sho ip ospf database external 192.168.38.0
            OSPF Router with ID (10.166.100.2) (Process ID 100)
  Routing Bit Set on this LSA in topology Base with MTID 0
  LS age: 194
  Options: (No TOS-capability, DC, Upward)
  LS Type: AS External Link
  Link State ID: 192.168.38.0 (External Network Number )
  Advertising Router: 3.3.3.3
  LS Seq Number: 8000000C
  Checksum: 0x56EF
  Length: 36
  Network Mask: /24
        Metric Type: 2 (Larger than any link state path)
        MTID: 0
        Metric: 100
        External Route Tag: 2000
Show command after apply distribute-list
LS age: 315
Checksum: 0x56EF
Length: 36
Network Mask: /24
       MTID: 0
       Metric: 100
Nagis
Regards, Nagis
Rolf
Hi Rolf,
Thank you so much. That works!! Now i understand the reason behind the issue. Thanks again for your time.
Nagis
Regards, Nagis
Nagis,
you're welcome. Thanks for the ratings and marking as answered!
Rolf
[EDIT/CORRECTION]:
"Disable" could be a misleading term; actually it's sufficient to make the interface OSPF passive or change the network-type (point-to-[multi]point), you can find the details in the linked document:
  • These conditions set the forwarding address field to a non-zero address:
    • OSPF is enabled on the ASBR's next hop interface AND
    • ASBR's next hop interface is non-passive under OSPF AND
    • ASBR's next hop interface is not point-to-point AND
    • ASBR's next hop interface is not point-to-multipoint AND
    • ASBR's next hop interface address falls under the network range specified in the router ospf command.
  • Any other conditions besides these set the forwarding address to 0.0.0.0.
