02-06-2012 02:40 AM - edited 03-04-2019 03:09 PM
Good morning to all,
can you explain me the differences between these commands ?
Can you give me some usage examples ?
Which one do you raccomend ?
Thanks in advance.
Solved! Go to Solution.
02-06-2012 04:10 AM
Hi Luca,
There should be no difference, if you have this option. I do not have it on 12.4(24)T5.
As I see it the "ip" option was introduced to accomodate the "ipv6" option => set ipv6 next-hop.
Dan
02-06-2012 04:04 AM
Hi Luca,
The set next-hop is not available in route-map configuration in recent IOSes. It is possible that it was simply a predecessor of the current set ip next-hop command. So for Policy Based Routing using ordinary route-maps, you do not actually have any alternative, as the only command I saw available in 12.4T IOS was the set ip next-hop.
Best regards,
Peter
02-06-2012 04:10 AM
Hi Luca,
Dan
02-06-2012 04:18 AM
Hi Dan,
i have found it in official guide
and Cisco website too.
