09-04-2025 12:44 AM
Hello experts. I have an issue with route-map.
*** Router A relevant configuration: ***
hostname Router_A
track 2 ip sla reachability
interface GigabitEthernet0/0
description LAN_A
ip address 100.100.100.3 255.255.0.0
standby 1 ip 100.100.100.2
standby 1 priority 110
standby 1 preempt
ip policy route-map pbr
interface GigabitEthernet0/1
description WAN_A
ip address 50.0.0.1 255.255.255.0
negotiation auto
ip route 0.0.0.0 0.0.0.0 100.100.100.1
ip route 20.0.0.0 255.0.0.0.0 50.0.0.2
ip access-list extended pbr-acl
permit tcp 100.200.200.0 any any eq 5555 2222
ip sla 2
icmp-echo 100.100.100.4 source-interface GigabitEthernet0/0
frequency 5
route-map pbr permit 10
match ip address access-list pbr-acl
set ip next-hop verify availability 100.100.100.4 1 track 2
route-map pbr permit 20
end
*** Router B relevant configuration: ***
hostname Router_B
description LAN_B
ip address 100.100.100.4 255.255.0.0
standby 1 preempt
description WAN_B
ip address 51.0.0.1 255.255.0.0
negotiation auto
ip route 20.0.0.0 255.0.0.0.0 51.0.0.2
end
After consulting with ChatGPT, everything appears to be in order, but that isn't the case.
For some reason, all traffic from the firewall (100.100.100.1) is being rerouted from Router_A to Router_B.
A tracerout from 100.150.150.150 to 20.20.20.20 shows:
4 <1ms <1ms <1ms 100.100.100.3
5 <1ms <1ms <1ms 100.100.100.4
6 4ms 4ms 4ms 51.0.0.2
Address 100.150.150.150 should not match the access list and therefore shouldn't be redirected to 100.100.100.4
Router_A#show route-map pbr
route-map pbr, permit, sequence 10
Match clauses:
ip address (access-lists): pbr-acl
Set clauses:
ip next-hop verify-availability 100.100.100.4 1 track 2 [up]
Policy routing matches: 178068588 packets, 181039745065 bytes
route-map pbr, permit, sequence 20
Match clauses:
Set clauses:
Policy routing matches: 0 packets, 0 bytes
This seems to show that all packets are incorrectly matching the access list, even though they shouldn't. Any ideas?
09-04-2025 12:50 AM
gDay @smeroz that is a great question. And from what u’ve shared, the issue looks like it’s coming from your access list. In ur config u have:
permit tcp 100.200.200.0 any any eq 5555 2222That syntax doesn’t look right. Because in Cisco ACLs, when u want to permit a range of ports, u need to use range, not just stack two ports. For example:
permit tcp 100.200.200.0 0.0.0.255 any range 5555 2222As it stands, the ACL may be behaving unexpectedly and matching more than you intended, which explains why all traffic is hitting sequence 10 of your route-map and being sent toward Router B.
I’d recommend tightening that ACL - specify the source subnet mask, fix the port syntax, and double-check with a show access-lists pbr-ac lwhile generating traffic from 100.150.150.150 to confirm it’s not matching.
And once the ACL is corrected, only the intended traffic should be policy-routed, and everything else should follow the normal routing table.......
hope it helps!
-Enes
CCNP x2 Enterprise
Your Friendly Networking Ninja
09-04-2025 12:56 AM
Firewall and two router run hsrp? Is that correct
Check that
1- FW must have defualt or static route toward VIP of HSRP
2- config pbr in both hsrp peer
MHM
09-04-2025 05:02 AM - edited 09-04-2025 05:02 AM
The syntax for your ACL doesn't look quite correct.
You have:
Can you change it to:
permit tcp 100.200.200.0 any eq 5555 eq 2222
You may have an extra 'any" in there and if you are trying to do individual ports you need to specify them with the eq statement.
Can you verify if this works after making the changes?
-David
09-04-2025 05:15 AM
I think if any wrong in ACL command the router reject it.
MHM
09-04-2025 06:15 AM - edited 09-04-2025 06:16 AM
Correct. The syntax of the ACL is invalid and the router will throw an error message.
However, if you just copy & paste the entire config proposed by ChatGPT into the router at once, most people will miss the error messages and then wonder why things are not working as expected...
@smeroz Do a 'show access-list' and post the output.
09-04-2025 06:41 AM - edited 09-04-2025 06:43 AM
Thats what I thought but the syntax looked like it has too many arguments.
09-04-2025 12:37 PM
thanks
let wait him share the show access list
MHM
09-07-2025 07:03 AM
Hello David. As I posted earlier, the "any any" was a typo. I later changed it to:
permit tcp 100.200.200.0 any eq 2222
But that didn't change anything.
09-04-2025 06:26 AM
He share this
So line 10 of PBR is work
Match clauses:
Set clauses:
Issue of redirect is config pbr with hsrp
The FW forward traffic to specific IP and router send re-direct (he can disable icmp redirect as workaround)
The network design is wrong
He need
FW point to VIP of hsrp
And both HSRP router have identical route' otherwise he will face always redirect.
""Again as workaround @smeroz can disable icmp redirect in interface""
09-04-2025 06:37 AM
The router does NOT check whether an ACL exists when you configure the route-map!
So if the creation of the ACL fails due to syntax errors, you can still create the route-map that refers to that ACL, even though it does not exist. The router treats this as a 'match any' and therefore all traffic is rerouted.
09-04-2025 12:11 PM
traffic is redirect check trace route he share
MHM
09-04-2025 12:23 PM
Yes, that's what I said.
If the ACL that is referenced in the route-map does not exist, the permit 10 statement works as a match any.
The router ignors the 'match ip address access-list pbr-acl' statement and without a valid match statement, it matches all traffic.
Hence all traffic is redirected.
09-04-2025 06:32 AM
@smeroz by the way
route-map pbr permit 20 <<- no need this' it pbr not route-map of filter or modify prefix
MHM
09-04-2025 01:56 PM
You just need to correct the ACL so it matches only the specific subnet and ports you want, then reference that ACL properly in the route-map. After fixing it, check with show access-lists to confirm hits are only on the intended traffic. Also make sure your firewall points to the HSRP VIP as the default gateway, and consider disabling ICMP redirects to avoid unwanted reroutes.
Best regards,
Stefan Mihajlov
Mark this post as Helpful if it helped you, and Accept as Solution if it resolved your question.
