05-13-2008 10:32 AM - edited 03-03-2019 09:56 PM
Should the route-map you'd expect to get the most hits be put first in the list to avoid any undo hits to the CPU or will it even matter if it's first or last in the list? My thinking is that the quicker it can jump out of the map the better the load on CPU.
Thoughts?
/rls
Solved! Go to Solution.
05-13-2008 10:53 AM
Correct in theory , but in reality if you're to the point where you depend on placement of entries in route-map or ACLs, the router you're using is already too small for your traffic.
05-13-2008 10:53 AM
05-13-2008 11:36 AM
I agree. Thank you for the quick response.
/rls
05-13-2008 12:04 PM
Thanks for the nice rating and good luck!
