route over mpls Link
Ibrahim Jamil
Level 6
Level 6
Hi Guys
i have 2 routers 2811 interconnected together ,1 of these router running in circuit with 2 Mbps over Internet the 2nd one use MPLS Circuit with a bandwidth of 4Mbps,how configure the routing to route over the MPLS while IPSec act as standby
thanks
Ibrahim
Marwan ALshawi
One simple way is
To use a routing protocol or static route with small administrative distance over MPLs link to reach the remote network
Use another static route with higher administrative distance to reach same remote network over the IPSec tunnel/link
Hope this help
