route path to as
cisco steps
Hi this may be easy, i did configure the default gtwy on r7 and I am able to ping it from the cloud.   I am not able ping from 192.168.3.0  network to 192.168.2.0 or 192.168.1.0 network , I did put in the network statement and neighbor statement on r7. I also tried ip route it seems not to work .
the interfaces on r7 are .1 and the interfaces on r1 and r2 are .2 .. I would like to to be able to reach .2 from the cloud. can you please help.
You first need to fix your IGP before worrying about BGP.  That means from the cloud you need to be able to ping the loopback address of router 1 and router 2.  Now, if you are not running any routing protocol then you need static routes from the cloud to both of the r1 and r2 loopback addresses.
Once your IGP if fixed and you can ping from the cloud to r1 and r2 and vice versa, then you can configure your BGP.
Reza
11 Replies 11
Reza Sharifi
What routing protocol are you running, OSFP, ISIS, RIP?
Reza
Tharak Abraham
Level 3
Level 3
We see that you are trying to reach the networks 192.168.1.0/30 and 192.168.20/30 from the cloud.
Did you advertise these on the networks in BGP with /30 mask ? Can you verify with the sh ip bgp
Moreover did you mean that the cloud has knowledge of these n/w ?
Could you check the BGP table from the cloud ? sh ip route bgp and let us know ?
Lei Tian
Make sure your R1 and R2 have the route for 192.168.3.0/24.
HTH,
Lei Tian
cisco steps
I am not planing to run ospf , eigrp or any, just bgp 100 for now that will be connected to an other bgp 200 . the cloud is number of user connected to a switch and the switch is connected to r7 , r7 provided redundant network to bgp 100 that is going to bgp 200 witch is not in the design yet, once I figure out how to communicate w/ r2 and r4 from the cloud I can then move to the next step witch is configuring bgp 200 . here some info ,
R7#sho run | begin router bgp
router bgp 100
no synchronization
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.252
network 10.1.2.0 mask 255.255.255.252
neighbor 192.168.1.2 remote-as 100
neighbor 192.168.2.2 remote-as 100
no auto-summary
R7#sho ip route
Gateway of last resort is not set
     7.0.0.0/32 is subnetted, 1 subnets
C       7.7.7.7 is directly connected, Loopback0
     192.168.1.0/30 is subnetted, 1 subnets
C       192.168.1.0 is directly connected, Ethernet1/0
     192.168.2.0/30 is subnetted, 1 subnets
C       192.168.2.0 is directly connected, FastEthernet0/1
R7#sho ip bgp
R7#sho ip bgp summary
BGP router identifier 7.7.7.7, local AS number 100
BGP table version is 1, main routing table version 1
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
192.168.1.2     4   100      12      12        1    0    0 00:09:41        0
192.168.2.2     4   100      12      12        1    0    0 00:09:36        0
R1#sho run | begin router bgp
router bgp 100
no synchronization
neighbor 10.1.1.2 remote-as 200
neighbor 10.1.5.2 remote-as 200
neighbor 192.168.1.1 remote-as 100
no auto-summary
R1#sho ip bgp summary
BGP router identifier 192.168.1.2, local AS number 100
10.1.1.2        4   200       0       0        0    0    0 never    Active
10.1.5.2        4   200       0       0        0    0    0 never    Active
192.168.1.1     4   100      15      15        1    0    0 00:12:49        0
R1#sho ip bgp
R1#sho ip route
     10.0.0.0/30 is subnetted, 2 subnets
C       10.1.1.0 is directly connected, FastEthernet0/0
C       10.1.5.0 is directly connected, FastEthernet0/1
R2#sho run | begin router bgp
router bgp 100
no synchronization
neighbor 10.1.2.2 remote-as 200
neighbor 10.1.6.2 remote-as 200
neighbor 192.168.2.1 remote-as 100
no auto-summary
R2#sho ip route
     2.0.0.0/32 is subnetted, 1 subnets
C       2.2.2.2 is directly connected, Loopback0
C       10.1.2.0 is directly connected, FastEthernet0/0
C       10.1.6.0 is directly connected, FastEthernet0/1
C       192.168.2.0 is directly connected, Ethernet1/0
R2#sho ip bgp
R2#sho ip bgp summary
BGP router identifier 2.2.2.2, local AS number 100
10.1.2.2        4   200       0       0        0    0    0 never    Active
10.1.6.2        4   200       0       0        0    0    0 never    Active
192.168.2.1     4   100      19      19        1    0    0 00:16:08        0
Thank you all for your help ,
cisco steps
I did manage to ping 192.168.1.1 witch was not the case before..but still no route to 192.168.2.1.. the 7 network is a loopback on r7 ..
R7#sho cdp n
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
R2               Fas 0/1            151        R S I      3660      Eth 1/0
R1               Eth 1/0            146        R S I      3660      Eth 1/0
router bgp 100
no synchronization
network 192.168.1.0 mask 255.255.255.252
network 192.168.2.0 mask 255.255.255.252
no auto-summary
router bgp 100
no synchronization
neighbor 7.7.7.7 remote-as 100
no auto-summary
router bgp 100
no synchronization
no auto-summary
C:\>ping 192.168.1.1 -t
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=3ms TTL=255
Reply from 192.168.1.1: bytes=32 time=5ms TTL=255
Reply from 192.168.1.1: bytes=32 time=2ms TTL=255
C:\>ping 192.168.2.1 -t
Pinging 192.168.2.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
There might be more problems but that will be hard to say without the output of "sh ip bgp" which was already requested.
It looks as if the neighbor relations R1-R7 and R2-R7 are not properly established.
From your last post, at least the following line is required on R7:
router bgp 100
network 192.168.3.0 mask 255.255.255.0
regards,
Leo
leo ,
here is the sho ip bgp
R7#sho ip bgp
BGP table version is 3, local router ID is 7.7.7.7
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 192.168.1.0/30   0.0.0.0                  0         32768 i
*> 192.168.2.0/30   0.0.0.0                  0         32768 i
it does show 2 valid best routes to network .1 and .2 , now I can still ping 192.168.1.1 from the cloud but not 192.168.1.2 and 192.168.2.1.
That seems to be a rather not so good design and use of BGP
An IGP like Ospf would be scale much better in your scenario.
1. Are you able to ping from R7 to all the other routers ?
2. Why have you advertised the connected networks in BGP ? i.e 192.168.1.0 and 192.168.2.0
The only network that upstream neighbor wants is the 192.168.3.0 network which has to be originated in R7.
3. How are the other routers getting to know about the 192.168.3.0 network ?
Reza
cisco steps
Thank yo reza,
I deleted the whole config. created ip route to reach other router then I configured BGP . that cleared my problem. I now I can use ospf or eigrp to advertise the route then aggregate the network , but that was not my Plan , I only wants BGP ,
Thank you all
You can not have connectivity/peering without some sort of IGP. That means, at minimum, you have to configure static routes to have readability first before you can bring up your BGP peers. You can of course use OSPF, ISIS, etc... to make life easier.
Reza
