route redistribution, order of execution
DARYLE DIANIS
I'm looking at router eigrp section that has redistribute static, redistribute bgp and a distribute-list statement.  Is there a particular order the router would evaluate these in?  This might not be the best configuration, but it's what I have to work with.
thanks,
cadet alain
There is no order.
The router looks for static routes and BGP routes in the RIB and only redistribute the ones installed and permitted in the distribute-list(whether via an ACL or a prefix-list).All other routes installed as static or BGP in the RIB won't get redistributed into the EIGRP process.
Alain
thanks, that does make sense.
