Route Reflector Configuration
abbas.ali
In a lab MPLS configuration, I have a PE1 router connected to External BGP, PE1 then connected to P Router and P Router connects to PE2 Router. PE2 connects to other external BGP Router. For Discussion, PE1, P and PE2 routers reflect MPLS Cloud where PE1 and PE2 connects to their respective Customers.
In order to configure full IBGP in an MPLS Cloud, I have configured P as a router reflector and PE1 and PE2 its clients. If PE1 receive an update from its customer will it be able to propogate that update to its Route Reflector P and will P router be able to propagate that to its other client PE2, and PE2 to its customer.
Reza Sharifi
Hi Abbas,
Yes, the PEs will propogate the routes to the RR, here is how:
iBGP routers are divided into Route Reflectors, Route Reflector clients and non-client Peers.
Routes received from a Route-Reflector-client is reflected to other clients and non-client neighbors.
Routes received from non-client neighbors are reflected to Route-Reflector-client neighbors only.
Also, if you only have 3 routers, you can logically fully mesh them together and not worry about RR.
Reza
