Route static and MP-BGP , change the weigth
a.auvinet
I have a network with MPLS/MP-BGP  actived.
device = ME-3800-X
It's ok.
But today, I would like change the weight of some route.
But, route are well advertised but without the weight changed.
My config :
router bgp 65000
 address-family ipv4 vrf vrf_tetra
  redistribute connected
  redistribute static route-map SET-WEIGHT-VRF-TETRA
 exit-address-family
ip route vrf vrf_tetra 10.28.0.0 255.255.0.0 10.28.200.118
access-list 99 permit 10.28.0.0 0.0.255.255
route-map SET-WEIGHT-VRF-TETRA permit 10
 match ip address 99
 set weight 200
Cordialy
12 Replies 12
Jon Marshall
BGP weight is only local to the router you define it on so it won't be carried in routing advertisements to other routers.
What exactly are you trying to achieve ?
Jon
Hooooo
I am an idiot.
Can i use LOCAL_PREF  for this ?
Cdlt,
Local preference will influence traffic leaving your site not traffic coming into your site.
It is not clear which one you want at the moment.
Jon
Ok.
I want influence other routers on my network.
In terms of traffic inbound to the router you are applying the configuration to ?
If so the usual way is to use AS path prepending.
Jon
I create a route-map , SET-AS-PATH-VRF-TETRA
route-map SET-AS-PATH-VRF-TETRA permit 10
match ip address 99
set as-path prepend 65002 65002
But, i have a probleme with static route.
It's not supported.
sw_pn_nts141_ric(config-router-af)#redistribute static route-map SET-AS-PATH-VRF-TETRA
% "SET-AS-PATH-VRF-TETRA" used as redistribute static into bgp route-map, set as-path prepend not supported
Cordialy,
Haven't got time to test at the moment but try creating a new route map for just the prepending and apply that route map to the neighbor(s) you want to influence.
Make sure in your route map you include a second permit statement for all the other routes you are not prepending.
Jon
Juste pour explain :
CPE1 ------FW1--------R_1-------------R3
ospf                               |                           |
CPE2-------FW2-------R_2|-------------r-4 ------->Other_net
On R_1  : static route  to  CPE1 via FW1
ON R_2 : static route  to  CPE2 via FW2
There is not routage protocol between CPEx etR_x
 I would like  influente other router, the traffic must be forwarder first  by R1   and backup by R2 if R1 is broken.
R1 / R2 R3 R4 , MPLS and VRF.
Are R1 and R2 internal to your network so the CE routers connect to the MPLS network which is not shown in your diagram ?
Apologies but it is still not clear what you are trying to do ie. influence traffic coming from the MPLS network or influence traffic going to the MPLS network ?
Jon
I am sure that there are things in the discussion that I do not understand well. But one thing I am clear about. The attempt to use a route map for prepending was applied to redistribution. And it was rejected because you prepend on route maps that are applied to what you advertise to a neighbor and not applied on how you learned the route.
I agree with Jon that we need a better understanding of the environment and clarity about what you are trying to achieve.
Rick
Rick
Sorry for my late.
It's OK now.
I try to explain to you  What I did.
Excuse me for my english.
  1. On R1 (edge MPLS network) , this routeur diffuse the client's static route to MPLS whithout change the metric
    1. Create IP SLA
      ip sla 99
       icmp-echo 10.28.200.110 (@ip cpe2) source-interface Vlan3200
       vrf vrf_tetra
       threshold 50
       timeout 1000
       frequency 5
      ip sla schedule 99 life forever start-time after 00:00:10
    2. Create IP track
      track 99 ip sla 99 reachability
    3. Add IP track on static route to LAN Client
       ip route vrf vrf_tetra 10.28.41.100 255.255.255.255 10.28.200.118 (# it's FW1)  track 99
    4.  BGP  on R1
      router bgp 65000 //
      address-family ipv4 vrf vrf_tetra redistribute connected redistribute static exit-address-family
  2. On CPE1 (edge cpe network) , this routeur diffuse the  static route of MPSL  to its  LAN client.There is also an IP SLA / TRACK pour static route to MPSL.
  3. On R2, like R1 but BGP redistribute static client  to MPLS Network  with metric of 200.
    1. Create IP SLA
      ip sla 99
       icmp-echo 10.28.200.106 (#@ip of cpe2) source-interface Vlan3200
       vrf vrf_tetra
       threshold 50
       timeout 1000
       frequency 5
    2. Create IP track
       ip route vrf vrf_tetra 10.28.41.100 255.255.255.255 10.28.200.118 (# it's FW2)  track 99
    4.  BGP  on R1
      router bgp 65000 //
      redistribute static metric 200
      exit-address-family
Thank you for the update. Glad to know that now it is OK.
Rick
Rick
