Route tagging questions - "blank" tag, and tags change?
PAUL TRIVINO
Level 3
Level 3
I have a couple questions about route tagging.  I don't currently use it but it may help with some issues.  As I understand it:
  • BGP tags routes "automagically" with the AS number
  • EIGRP does not tag routes unless explicitly told to
  • OSPF does not tag routes unless explicitly told to
(Actually I do use tagging in a few places but as of now, only to tag static routes, so that I do or do not redistribute them).
Questions:
Does a tag of "0" indicate an "untagged" route? I.e., using "match tag 0" in a route-map would find ONLY routes not previously tagged? (When I do "sh ip route tag 0" on my EIGRP-only router, this seems to be the case.)
If one redistributes a route, say between EIGRP and BGP or vice versa, and you don't *explicitly" tag or retag the route, does the tag it has ever change?
Thanks.
Paul
milan.kulik
Level 10
Level 10
AFAIK, BGP does not use simple route tags (you can use communities, e.g., instead).
But when you are redistributing a prefix from BGP to some IGB, it's tagged by a value equal to the router BGP AS number by default.
I believe tag=0 is the default value used for each route in the RIB.
It might be interesting to configure a route-map used for a route redistribution and setting the tag value to 0!
See here http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/command/iri-cr-book/iri-cr-s1.html#wp4048265148
and here
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/command/iri-cr-book/iri-cr-s1.html#wp7981727100
for more details.
Best regards,
Milan
