route target import export not always working
micfan
I have an ASR L3 MPLS implementation.  Seems like that after a while we can no longer import export between VRF's.
this is working and importing exporting for the past VRF's , but as we expanded and added new VRFs to import into our shared VRF's , routes are not importing or exporting.
Cisco IOS XE Software, Version 16.06.02
vrf definition xxxx(shared)
rd 10.100.100.62:27
route-target export xx11:1127
route-target import xx11:1127
route-target import xx11:1123
route-target import xx11:1122
address-family ipv4
exit-address-family
vrf definition XXX1(client)
rd 10.100.100.62:22
route-target export xx11:1122
These two do not import or export to each other.
This client however imports and exports from shared.
vrf definition clientworking
rd 10.100.100.62:23
route-target export xx11:1123
I have tried to fix this with and without a single route targed for the clients needing to access the shared services.
Thanks for the help !!
26 Replies 26
Since you are running XE, this is not the ASR9K, so which platform: ASR 901/902/903/907/920/1000? If 902/903/907, which RSP?
First thought that comes to mind is that you may be running out of TCAM to store IPv4/IPv6/VPNv4/VPNv6 routes. Which SDM template are you using? BGP debugs should tell you whether you are actually importing to and exporting from the VRF. If the imports/exports are actually taking place in the BGP control plane, then this may indicate a failure to write FIB entries to TCAM.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
micfan
its an ASR 1001x.  If i create new VRFs or even just new router-targets it will import .  Just using the ones already configured does not work.  creating new unique targets for every import export combo has not been a practical solutions
My ASR XE experience was with the 9xx products, not the 1K line where I am clueless. My impression is that the A1K has significantly more TCAM resources than the A9xx, which are temperature hardened and targeted at specific SP use-cases. TCAM may not be the issue for what you are seeing on the A1K.
I still think you might look at various BGP & VRF debugs to confirm whether the imports and exports are actually happening in the control plane or not.
Any have advice on what show commands or debugs will help
Just guessing, but maybe try...
  debug ip bgp updates
  debug ip bgp ipv4 unicast <A.B.C.D neighbor address>
  debug ip bgp vpnv4 unicast import
  debug ip bgp vpnv4 unicast updates
  debug bgp vrf
  debug vrf ipv4
Enter "?" after each of the above commands to see what options are available. The debug output to the console/vty might be overwhelming, so you might send output to a file instead.
Hi @micfan ,
Can you try the following commands to see if they will fix it:
R1#clear ip route vrf XXX1 *
R1#clear bgp vpnv4 uni * soft
Hello Harold.  You helped me with an MPLS issue once in the past !!
I tried those commands already with zero luck.  I just ran them again for good measure on a different VRF with the issue.
Thanks as always
Mike
Hi @micfan ,
Can you please provide the "show runn vrf" command output?
micfan
R1#sho run vrf x1(client)
Building configuration...
Current configuration : 1606 bytes
vrf definition xxx(client)
rd x.x.100.62:22
address-family ipv4
exit-address-family
interface Tunnel29
description xxx(client)-LD1-1
vrf forwarding xxx(client)
ip address x.x.0.18 255.255.255.254
ip tcp adjust-mss 1379
tunnel source Loopback101
tunnel mode ipsec ipv4
tunnel destination
tunnel protection ipsec profile ipsec-xxx(client)-ikev2
ip virtual-reassembly
interface Tunnel37
description xxx(client)-DALLAS-LD1
ip address x.x.0.16 255.255.255.254
tunnel destination
tunnel protection ipsec profile ipsec-xxx(client)-dallas
router bgp 65501
address-family ipv4 vrf xxx(client)
redistribute static
neighbor x.x.0.17 remote-as xxx
neighbor x.x.0.17 local-as xxx no-prepend
neighbor x.x.0.17 description xxx(client)-xxx
neighbor x.x.0.17 timers 10 30 30
neighbor x.x.0.17 activate
neighbor x.x.0.17 default-originate
neighbor x.x.0.17 soft-reconfiguration inbound
neighbor x.x.0.17 prefix-list pl-xxx(client)-out out
neighbor x.x.0.19 remote-as 64513
neighbor x.x.0.19 local-as 48412 no-prepend
neighbor x.x.0.19 description xxx(client)-xxx
neighbor x.x.0.19 timers 10 30 30
neighbor x.x.0.19 activate
neighbor x.x.0.19 default-originate
neighbor x.x.0.19 soft-reconfiguration inbound
neighbor x.x.0.19 prefix-list pl-xxx(client)-out out
exit-address-family
end
R1#sho run vrf xxx(shared)
Current configuration : 2177 bytes
vrf definition xxx(shared)
rd 10.100.100.62:27
address-family ipv4
exit-address-family
interface TenGigabitEthernet0/0/1
no ip address
interface TenGigabitEthernet0/0/1.1101
encapsulation dot1Q 1101
vrf forwarding xxx(shared)
ip address x.x.101.2 255.255.255.252
interface Tunnel1305
description xxx(shared)
ip address x.x.128.19 255.255.255.254
tunnel source
tunnel destination
interface vasileft1
ip address x.0.0.1 255.255.255.252
no keepalive
router bgp xxx
address-family ipv4 vrf xxx(shared)
redistribute static
neighbor x.x.101.1 remote-as xx11
neighbor x.x.101.1 local-as 63301 no-prepend
neighbor x.x.101.1 description xxx
neighbor x.x.101.1 activate
neighbor x.x.101.1 allowas-in 1
neighbor x.x.101.1 soft-reconfiguration inbound
neighbor x.x.101.1 prefix-list pl-signaling-out out
exit-address-family
end
I removed names and public ip/as numbers.
thanks for looking everyone.
Hi @micfan ,
Can you share the "show bgp vpnv4 uni all <prefix/prefix-length> output for one of the prefixes that should be shared between the client and the shared vrf.
Point 1Can you check if bgp of new vrf get router ID or not?
Point2
Shared need to export only xx11:1127  not import export same rt number.
micfan
we use the import in conjunction with the export so we have reachability to these prefixes via our redundant paths in other DC.
R1#sho bgp vpnv4 uni all x.x.72.32/28
BGP routing table entry for 10.100.100.62:22:x.x.72.32/28, version 42491
Paths: (3 available, best #2, table tours)
Advertised to update-groups:
2478
Refresh Epoch 1
64513, imported path from 10.100.100.63:22:x.x.72.32/28 (global)
10.100.100.63 (metric 210) (via default) from 10.100.100.50 (10.100.100.50)
Origin incomplete, metric 0, localpref 100, valid, internal
Extended Community: RT:65411:1122
Originator: 10.100.100.63, Cluster list: 10.100.100.50
mpls labels in/out 131/50
rx pathid: 0, tx pathid: 0
Refresh Epoch 1
64513
100.116.0.19 (via vrf tours) from 100.116.0.19 (x.x.72.4)
Origin incomplete, localpref 100, valid, external, best
mpls labels in/out 131/nolabel
rx pathid: 0, tx pathid: 0x0
Refresh Epoch 1
64513, (received-only)
BGP routing table entry for 10.100.100.63:22:x.x.72.32/28, version 42492
Paths: (2 available, best #2, no table)
Not advertised to any peer
Refresh Epoch 1
64513
10.100.100.63 (metric 210) (via default) from 10.100.100.51 (10.100.100.51)
Originator: 10.100.100.63, Cluster list: 10.100.100.51
mpls labels in/out nolabel/50
Refresh Epoch 1
64513
Origin incomplete, metric 0, localpref 100, valid, internal, best
Just change rt of import and check
