Multicast questions.
I am running IGMP V2 and Sparse mode multicast. Do i need an RP or not.?
6 Replies 6
balaji.bandi
its all depends on the deployment : (what RP fix the issue explained below )
cisco official guide :
https://www.cisco.com/c/en/us/td/docs/ios/solutions_docs/ip_multicast/White_papers/mcst_ovr.html
others just in short :
https://networklessons.com/multicast/multicast-pim-sparse-mode
BB
NUSFETLEN
RP is needed for Sparse mode to work.
If you are not already too far down the path of PIM-SM and IGMPv2, you might consider PIM-SSM and IGMPv3 instead. Unlike PIM-SM, SSM does not require RPs, eliminates group address collisions and provides a modicum of security against injection of bogus multicast traffic.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Joseph W. Doherty
Well, according to Cisco a RP is required for PIM-SM, more details here.  The details show various ways of providing the RP.
If you would additional information about PIM multicast, including PIM-SSM and IGMPv3, as mentioned by @Ramblin Tech , you might start here.
Hello
Yes you will require to configure a RP, be it statically or dynamically via BSR
Kind Regards
Paul
M02@rt37
Hello @tonymalpass62726,
You need RP address!
Best regards
