Route target under vrf against route target under address family
Derek Mayabi
I have a doubt.Please consider the below config.
vrf definition XYZ
rd 100:1
route-target export 109:1
route-target import 109:1
address-family ipv4
exit-address-family
Can someone tell me how the functionality  changes when route target is defined under vrf definition and the same defined under address-family ipv4 are different ?
Jose Jara
Level 3
Level 3
Hi Derek,
when you specify the route-target under address-family ipv4 it will affect only IPv4 prefixes. So, the IPv4 routes that you will get imported or you will export will have the RT specified, in this case 109:1. If, for example, you´re using IPv6 as well and you do not defined an explicit Route Target under address-family ipv6, the RT that will get IPv6 prefixes will be the one that is used under vrf definition.
Hope this helps,
Jose.
