Router 1602
Spinu Viorel
I have this old router...I want to use it, but the WIC port is a serial port and I have an Ethernet RJ-45 cable from my ISP. What can I use to convert from RJ-45 to serial?
The router is modular. Can I but another Ethernet card and use it to connect to my ISP?
thank u!
andrew.prince
Level 10
Level 10
Get yourself an AUI transceiver - this will give you another Ethernet Interface.
HTH>
Spinu
In your post you refer to the provider connection as "Ethernet RJ45". I am not clear whether you really mean that it is an Ethernet connection or whether you might mean RJ45 and you normally associate that with Ethernet. Some serial connections come as RJ45 (especially when conecting to a CSU/DSU or a router with a built in CSU/DSU. Can you clarify what kind of connection the provider is giving you?
Rick
Rick
I have a cable modem connection, and from the modem a RJ45 cable to my computer .. and I want to put this router between the modem and my computer. It is an Ethernet connection.
Spinu
This clarification is helpful. The cable modem certainly uses Ethernet for the interface that you will use. So you would need 2 Ethernet interfaces. I am not sure that the 1602 supports 2 Ethernet interfaces.
Rick
Rick
