IP Base and supported features
Kevin Melton
Level 2
Level 2
Does IP base support dynamic routing protocols such as BGP and EIGRP?
John Blakley
Depending on the type of equipment you have, BGP and EIGRP is supported on 12.4(11)T for x800 (1800/2800/3800) series routers.
If you have something different, you may want to look here: http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp and do a search for BGP and EIGRP and limit it by your hardware.
HTH,
John
HTH, John *** Please rate all useful posts ***
Actually I am going to replace the IOS image on a bunch of 2610 routers. Right now they are all handling bgp as well as eigrp. I need to move them to a code that will support SSH that is inclusive of BGP and EIGRP. Our RAM is limited on these boxes to about 96 MG, so I am limited in feature sets that I can use. That is why I was asking about IP Base.
the current version running on these boxes is 12.3.6a
